Znikające pixele
Przemek_E39
Było już troche o tym... :search:
Nawet nie "trochę", tylko dużo, np. :
http://autobmwklub.triger.com.pl/forum/viewtopic.php?t=7996
Stronka
PROSZĘ TO PRZETŁUMACZYĆ !!
Instructions for removal and cleaning of MID (multi information display center)(the in dash unit containg the speedometer and tachometer) to restore pixels.
1.Remove 2 screws above tach/speedo with a T10 torx driver.
2.Pry out upper lip of housing with a flat blade screwdriver.
3.Disconnect 3 wire harnesses in the back of the housing and slide assembly toward passenger side of vehicle. (Make sure steering wheel is down and telescoped fully)
4.Place assembly face down on some type of soft towel and find and remove the wire harness going from the speedo/tach assembly to the module attached to the back. (Black plug at the top of assembly).
5.Push button on the bottom of assembly and slide the module sideways to free it from the front assembly.
6.Locate the five “X” type connectors holding the front onto the main housing. Twist these connectors slightly so they line up with the holes on the housing.
7.Press the four clips (2 on top/2 on bottom) and slide the assembly out through the back of the assembly holding the front clear covering (that covers the faces of the gauges).
8.Now lay the tach/speedo assembly face up on the towel and remove all of the torx screws on the face (about 8-10), this will NOT allow you to open the housing, but it will loosen it enough so you can get a spray nozzle into the circuit board under the cover.
9.Spray any and all connections you with the contact cleaner (non-residue/quick drying/plastic safe). Quickly dry the connections with compressed air (be sure to hold can upright to prevent liquid from being expelled)
10.Spray all holes and connectors and the connectors that plug back into the dash board. I also sprayed the actual connectors in the dash as well.
11.Reassemble the entire unit and make sure it is DRY before reinstalling in the vehicle.
This is what worked for me, it restored all of the pixels to 100% brightness.
Good Luck to all, BE CAREFUL!!!!
www.7er.pl > BMW7 Klub Polska
:mrgreen: - znany "prosty przepis".
Pokrótce :
Rozebrać licznik i popryskac wszystko sprayem - "contact cleaner (non-residue/quick drying/plastic safe)" - czasami skuteczne, a częściej tylko krótkotrwała poprawa ... i trzeba uważać aby mieć odpowiedni spray, aby więcej nie zniszczyć ...
Stronka
Moje zegary mialy dokladnie ten sam defekt jak kupilem auto. Nie
dosyc ze znikaly piksele w alfanumerycznej czesci komunikatow,to jeszcze
zaczely znikac w polach gdzie jest przebieg i przebieg dzienny.
Naprawa kosztowala 300 pln, na czas naprawy dostalem zastepcze zegary.
Rozwiazanie z psikaniem sprayem bylo juz dyskutowane i ogolnie nie
jest polecana metoda - mozna zrobic wiecej szkody niz pozytku.
Powodem defektu jest mechaniczny brak kontaktu pomiedzy wyswietlaczem a elektronika i zaden cudowny spray tutaj nie pomoze a
moze jeszcze pogorszyc sprawe robiac zwarcia nie tam gdzie potrzeba.
Punto75>BravoGT>MB260E>MBC280>*PuntoHLX>MBC320>MBE50AMG>VectraC>BMW528 . it's nice to be important but it's more important to be nice
>>> psychop's lab mike.xray.pl
3 miesiące temu zrobiłem w swojej basi metodą sprayu.
5 - 6 godzin trwała zabawa z rozkręcaniem aż do taśmy mid oczywiście małe kłopoty itp. - wynik końcowy : wszystko super do dziś wszystko gra być moze faktycznie kiedy przyjdą zimniejsze dni to pixele powtórnie będą zanikać ale poinformuje o tym na forum.
  • 4 miesiące temu...
Olejus jak sie maja liczniki na dzien dzisiejszy :?: :?: :?:
