Instalacja DIS na Vmware
Hi,
got stuck on the same thing when I first tried launching DIS. There is that hidden menu in the program itself, where you can manually set up your network devices. You need to remove the network device and than add a new one by using the IP 192.168.68.30. I'm not able to recall the other settings, but you just need to follow this instruction (just download the PDF file) from the step 44. It's quite straight forward, so you shouldn't have any problems. Hope it does the job.
  • Odpowiedzi 1 tys.
Hello to all:
I was hoping someone on the board Could help me figure out why and get a NET 0016 Host error When running the API test in DIS. All Has Been Properly installed and configured. INPA works flawlessly with absolutely no problems at all. I am running Windows XP Professional with SP3 on a Sony Vaio Laptop Dual Core 1.6. I had to reformate the computer due to a computer virus and Since this and have been unable to pass the API Test. My previous installation Worked flawlessly until the machine got a worm virus and i had to reformate the hard drive. Since this, and have not been able to indictment the API Test. I would be grateful That is anyone can help me out and figure this out. I have snapshots of my VMware machine with all-IP addrsses if anyone would like to see them.
I am running Vmware 6.0
Regards,
Mark
Check ip address in ediabas.ini. Double check network settings in VMware. Enable VMware 5.xx emulation. Switch off antivrus, firewall, etc.
In DIS go to administrator, touch pad calibration. Chose configure process. Make all of them not running and apply configuration. Make all of them running and apply configuration.
Removing cards can kill DIS.
Hi,
Hi and thankyou for the reply. I have tried removing the network device a number of times and still cannot pass the API Test. I ran a ping 192.168.68.30 and the results were 4 packets received and 4 sent 0% lost. I figured that with this result i would pass the API, but have not been able to do so. Everything has been properly configured and installed. I do not know what else to check and what else to do to make this work.
Regards,
Mark
Hello to all:
Regards,
Mark
Thankyou for your reply. Antivirus/Firewall are always disabled when i work with DIS. In DIS as you say, do you mean that i change all the processes to not running and run an API Test and if it does not pass then go back and set them all to run and redo the API test? Is this what you mean?
In my ediabas.ini file, IP is: 192.168.68.1 Hmm, i have never used the emulation option in Vmware. I am running Vmware 6.0 and have not seen the emulation you mention. I am going to have to check and see as the instructions i used to install did not specify this and my first installation was completely successful using these same instructions. Everything turned downhill after i had to reformat my hard drive because of a worm virus.
Regards,
Mark
here are a few snapshots of my setup
I have run INPA successfully, have deleted and reinstalled the ethernet adapter from scoadmin, restarted the kernel and as i indicated, all necessary procedures have been done to get this working.
http://s958.photobucket.com/albums/ae66/se93/
Regards,
Mark
Mam problem z instalacją DIS-a. Czy ktoś może mi napisać krok po kroku jak zainstalować DIS-a 44?? Lub jakoś udostępnić filmiki z instrukcją??Kupiłem interfejs od nerwusa, owszem dostałem płytke z instrukcją ale jest uszkodzona:( becia stoi w garażu a nerwus jest na urlopie i wraca dopiero 18-go:((
Hehe, ja własnie postawiłem w końcu DISa. Nie mogłem sobie poradzić, więc odpuściłem i skupiłem się na Inpie i NCS. Ale spróbowałem na nowym laptopie i o dziwo - robiąc wszystko jak w instrukcji (czyli dokładnie tak, jak robiłem wcześniej) - tym razem śmignęło bez problemu. Nie obeszło się bez zmian w ukrytym menu, ale reszta poszła super :cool2:
Ja również przyłączę się do prośby Kolegi jaro987 - jeśli ktoś dysponuje odpowiednią instrukcją lub przewodnikiem filmowym do instalacji DIS-a to prosiłbym o pomoc i udostępnienie w jakiejś formie stosownych materiałów :)
Jak wyłączyć Kalibracje ekranu na dis v39?
Link we wcześniejszym poście rozwiązującym problem nie działa :(
Próbowałem przyciskiem "windows" i "enter", wyłącza się, ale pojawia się czarny ekran z kursorem i tak wisi w nieskończoność...
Po restarcie na ostro, znów jest kalibracja.
Powiesiłeś dziada. Spróbuj przejść do konsoli x kombinacja alt (lub ctrl) + Fx. Nie pamiętam w tej chwili dokładnie którym. Jeżeli X'y nie rusza to może chociaż zobaczysz logowanie do konsoli i tutaj wpisz root i hasło 12345 (nr dealera). Później spróbuj shutdown polecania.
niestety w haśle nie mogę nic wpisać.
Może z innej beczki, ma ktoś może CIP-a na v44, bo mam go tylko na v39 ale niestety na nim nie mogę wyłączyć kalibracji i przejść do ukrytego menu
edit:
hasło wpisywałem ale nie było efektu.
temat nieaktualny bo nie chce mi się męczyć z tym v39
zarzucę sobie osobno sss zamiast cip na dis
Edytowane przez krzysiek80r
Prawdopodobnie tak Ci się tylko wydaje. To, że nie wyświetlają się żadne znaki (jak np. gwiazdki w Windowsie) to nie znaczy, że nic nie wpisujesz. Po prostu wklep hasło i naciśnij Enter. Jeżeli nie to miałeś na myśli to przepraszam, ale nie wczytywałem się w Twoje wcześniejsze posty.
Holera, wciskam ten "esc" i nic się nie dzieje. Mało tego, u mnie sam proces startu instalacji EasyDIS'a wyglada nieco inaczej. :mad2:
Panowie, nie daje rady.
Próbowałem już na trzech komputerach, utykam w tym samym miejscu.
Zostaje mi kursor i kupa taka, że palce lizać.
W Video instrukcji od Nerwusa zauważyłem jedną nieprawidłowość.
W filmie nr 8 w edycji parametrów wirtualnej maszyny CDRom ustawiany jest na konkretny dysk (w tym przypadku napęd wirtualny), w filmie nr 10 ten CDRom ustawiony jest na "auto".
Poza tym u mnie podczas startu wirtualnej maszyny VMWare nie reaguje nie tylko na ESC, na F2 i F12 też nie.
Napiszcie proszę czy macie na to jakiś sposób, bo przyjdzie mi się pociąć skórą od salecesonu...
Ja też na tym stanąłem i zeszło mi kilka godzin aż zaczaiłem z czym problem, aż się głupio przyznać ale wystarczy myszka kliknąć w to okienko które pojawia się po włączeniu wirtualnej maszyny i wszystkie przyciski działają
Nie wiem co robię źle... nie przechodzi mi testu API oraz nie widzi głowicy.
VMvare w wersji 7.0 i trochę inne konfigurowanie sieci w Vmvare, ale myślę, że skonfigurowałem ją dobrze.
System Windows 7 64 bit.
Poniżej załączam zdjęcie jak to u mnie wygląda.
Może ktoś pomoże mi w skonfigurowaniu tego do końca? :)
http://i53.tinypic.com/e6u69w.jpg
Witam!!
Bardzo proszę o pomoc. Nie wiem co robię źle. Załączam screeny oraz plik edibas.ini
http://img829.imageshack.us/gal.php?g=ustawieniasieci.png
;EDIABAS 6.4.7 Configuration
[Configuration]
; EcuPath
; Description : ECU file path
; Default = .
EcuPath =C:\EDIABAS\ECU
; SimulationPath
; Description : Simulation file path
; Default = .
SimulationPath =C:\EDIABAS\SIMULATION
; TracePath
; Description : Trace file path
; Default = .
TracePath =C:\EDIABAS\TRACE
; CodeMapping
; Description : Character mapping file path
; Default = .
;CodeMapping = C:\EDIABAS\BIN\ansi2oem.tab
; TraceSize
; Description : Maximum size of each trace file [KB]
; Value : 0..32767
; Default = 1024
TraceSize = 32767
; ApiTrace
; Description : Enable/Disable API/User trace
; Value : 0 = Trace disabled
; 1 = User trace
; 2 = User trace + time stamp
; 3 = User trace + time stamp + process id (Win32)
; 4 = Function trace
; 5 = Function trace + time stamp
; 6 = Function trace + time stamp + timing
; 7 = Function trace + time stamp + timing + process id (Win32)
; Default = 0
ApiTrace =0
; IfhTrace
; Description : Enable/Disable IFH trace
; 1 = User trace
; 2 = User trace + interface
; 3 = User trace + interface + time stamp
; Default = 0
IfhTrace =0
; IfhnTrace
; Description : Enable/Disable IFH network trace (with XREMOTE)
; 1 = User trace
; Default = 0
;IfhnTrace = 0
; SystemTraceSys
; Description : Enable/Disable system trace (runtime system)
; Trace levels 1..7
; Default = 0
SystemTraceSys = 0
; SystemTraceBip
; Description : Enable/Disable BIP trace (runtime system)
; Trace levels 1..7
; Default = 0
SystemTraceBip = 0
; SystemTraceIfh
; Description : Enable/Disable IFH system trace
; Trace levels 1..7
; Default = 0
SystemTraceIfh = 0
; SystemTraceNet
; Description : Enable/Disable network trace
; Trace levels 1..7
; Default = 0
SystemTraceNet = 0
; BipDebugLevel
; Description : BIP debug level of ECU files
; Value : 0..32767
; Default = 0
BipDebugLevel = 0
; UbattHandling
; Description : Ubatt ON/OFF handling
; Value : 0 = Ubatt ON/OFF: No EDIABAS error
; 1 = Ubatt ON/OFF: EDIABAS error
; Default = 1
UbattHandling = 0
; IgnitionHandling
; Description : Ignition ON/OFF handling
; Value : 0 = Ignition ON/OFF: No EDIABAS error
; 1 = Ignition ON/OFF: EDIABAS error
; Default = 1
IgnitionHandling = 0
; ClampHandling
; Description : automatic check of clamps for Ubatt and Ignition
; Value : 0 = no automatic clamp check with send_and_receive
; 1 = automatic clamp check with send_and_receive
; Default = 1
;ClampHandling = 1
; TaskPriority
; Description : EDIABAS process/thread priority (only Win32/16)
; Value : 0 = Optimal EDIABAS performance = 8
; 1 = Minimal EDIABAS performance
; 10 = Maximal EDIABAS performance
; Default = 0
TaskPriority = 0
; LoadWin32
; Description : Map EDIABAS Win16 calls to EDIABAS Win32
; Value : 0 = Win16/32 Mapping disabled (Win16-->Win16)
; 1 = Win16/32 Mapping enabled (Win16-->Win32)
; Default = 0 for Windows 9x/Me
; Default = 1 for Windows NT4/2000/XP
;LoadWin32 = 0
; SystemResults
; Description : Enable/Disable system results (ubatt/ignition/jobstatus)
; Value : 0 = Disable system results
; 1 = Enable system results
; Default = 1
SystemResults = 1
; RetryComm
; Description : Repeat failed communication automatically (1x)
; Value : 0 = Retry disabled
; 1 = Retry enabled (1x)
; Default = 1
RetryComm = 1
; Simulation
; Description : Enable/Disable ECU simulation
; Value : 0 = Simulation disabled
; 1 = Simulation enabled
; Default = 0
Simulation = 0
; Interface
; Description : Connected diagnosis interface
; Default = STD:OBD
Interface =STD:OBD
; Additional information (in German) :
; Bitte beachten: Der HW-Treiber fuer das Interface muss installiert sein!
; Interface = STD:OBD
; Beschreibung : Serieller Pegelwandler (Nachfolger von ADS / Anschluss an OBD-Dose)
; Installation : \EDIABAS\HARDWARE\OBD\ODBSETUP (nur noetig fuer WIN NT4, WIN 2000, WIN XP)
; INI-Datei : Suchreihenfolge analog zu EDIABAS.ini
; Unterstuetzung : WIN3.xx : Nein
; WIN95,98 16-Bit : Ja
; WIN95,98 32-Bit : Ja
; WIN NT 4.0 : Ja
; WIN XP : Ja
; Interface = STD:FUNK
; Beschreibung : Funk-Diagnose Interface MDA von Fa. Siemens
; Installation : keine
; INI-Datei : FUNK.INI
; Unterstuetzung : WIN95,98 16-Bit : Ja
; WIN NT 4.0 : Ja
; WIN XP : Ja
; Interface = ADS
; Beschreibung : Serieller Pegelwandler (Anschluss an Diagnose-Dose)
; Installation : \EDIABAS\HARDWARE\ADS\ADS32\ADSSETUP (nur fuer WinNT4 noetig)
; INI-Datei : keine
; WIN95,98 32-Bit : Nein
; WIN NT 4.0 : Ja
; WIN XP : Ja
; Interface = KBUS
; Beschreibung : Serieller Pegelwandler (Anschluss direkt an K-Bus oder I-Bus)
; INI-Datei : keine
; WIN NT 4.0 : Ja
; WIN XP : Ja
; Interface = EDIC
; Beschreibung : Serielles , PCMCIA , PC-Card Interface von Fa. Softing
; Installation : \EDIABAS\HARDWARE\EDIC\SETUP.EXE
; INI-Datei : EDICFW.INI, EDICHW.INI
; WIN NT 4.0 : Ja
; WIN XP : Ja
; Interface = EDICC
; Beschreibung : EDIC-Card C oder EDIC-Card 2 CAN-Interface von Fa. Softing
; INI-Datei : XEDICC.INI
; WIN NT 4.0 : Ja
; WIN XP : Ja
; Interface = STD:CAN
; Beschreibung : PCMCIA CAN-Interface CanCardX/XL von Fa. Vector
; Installation : keine (ausser Installation der CAN-Karte)
; INI-Datei : CAN32.INI
; Unterstuetzung : WIN95,98 16-Bit : Nein
; WIN NT 4.0 : Ja
; WIN XP : Ja
; Ansprechpartner: Hr. Jusko
; Telefon : +49-(0)89/382-35891 (Hotline)
; email : [email protected] (Hotline)
; Interface = STD:ADS4MOST
; Beschreibung : Most-Interfaces von Fa. Oasis
; Installation : keine (ausser Installation der Oasis-Karte)
; INI-Datei : ADS4MOST.INI
; Unterstuetzung : WIN95,98 16-Bit : ?
; WIN95,98 32-Bit : ?
; WIN NT 4.0 : Ja
; WIN XP : Ja
; Ansprechpart.: Hr. Rowedder
; Telefon : 089 / 382-29159
; Interface = REMOTE
; Beschreibung : Anbindung eines EDIABAS-Interfaces über TCP/IP
; Installation : Anpassung der Einträge in [TCP] auf beiden Seiten (ins.: RemoteHost, Port)
; INI-Datei : keine
; WIN NT 4.0, XP : Ja
; WIN XP : Ja
; Sonderfall : Interface OPPS
; Interface = REMOTE:name
; INI-Datei : REMOTE.INI (insbesondere für Parallelbetrieb notwendig)
; In REMOTE.INI stehen unter [name] spezif. Einstellungen(z.B.: RemoteHost, Port)
; WIN XP : Ja
; NetworkProtocol
; Description : Network protocol
; Default =
NetworkProtocol = TCP
;TCP/IP Configuration
[TCP]
; RemoteHost
; Description : server address/name
; Default =
RemoteHost =192.168.68.30
; Port
; Description : IP communication port
; Value : 1000 < port < 30000
; Default =
Port = 6801
;TimeoutConnect
; Description : Timeout for establishing the connection
; Default = 5000
TimeoutConnect = 2000
;TimeoutReceive
; Description : Timeout for receiving a message
; Default = 5000
TimeoutReceive = 2000
;TimeoutFunction
; Description : Timeout for a long function
; Default = 59000
TimeoutFunction = 10000
;DisconnectOnApiEnd
; Description : Enable/Disable Disconnection with function call ApiEnd
; Value : 0 = Disconnection disabled
; 1 = Disconnection enabled
; Default = 0
;DisconnectOnApiEnd = 1
;InitCmd
; Description : Initialization command (normally for OPPS)
; Default =
;InitCmd0 = FE,04,00,03,01
;InitCmd1 = FD,05,00,03,01
; End Of File EDIABAS.ini
[XEDIC]
EdicApiPath= C:\EDIABAS\EDIC\EIDBSS
EdicInterfaceNo= 2
kto wie jak porządnie skonfigurować VmWare7 na Windows 7 64-bit żeby odpalić DISa? INPA śmiga aż miło a z DISem mase problemów. Przy połączeniu wywala błąd 200.166 -dodam ze antywirus i firewall sa wylaczone...
api test
http://img214.imageshack.us/img214/17/disw.png
pozdr
Tez niestety mam problem z uruchomieniem DISa. Jak uruchomie api test to wychodzi mi jakies menu gdzie mam do wyboru 14 podpunktów i niewiem czy to dobrze czy zle?
Dodam ze pracuje na VMware 7.0 i mam sciagniety gotowiec v44 cod i v57 diag i odpala sie bez problemu. Niewiem tylko czy w ustawieniach mam wszystko oki bo ten nowszy vmware sie inaczej troche ustawia ale wartosci powstawiałem takie same.
Jak uruchomie IFHS i Diaghead i potem włączam vmware to czasem wyskakuje mi error ze cos tam głowica chce zrobic na nieistniejącym hoscie (przepraszam ale nie zapisałem dokladnie komunikatu)
Interfejs mam ADS i tak mam zainstalowaną inpe która chodzi bez problemu.
Bede wdzieczny za pomoc.
Te 14 podpunktów tzn ze jest ok. Co do drugiej opcji to bez dokładnego błędu nic nie pomogę (włącz emulator głowicy i sparuj ja w DIS)
api test
pozdr
api test
pozdr
Jeżeli INPA działa to DIS już małe piwo. Poprawne ustawienie siec to podstawa.
co to moze być przy inpie gdy ją odpalam batery jest na on a ignition na off co tam czeba zmienić?i prosze żeby ktoś napisał coś na temat tego testu api na disie bo już niemam siły :mad2:
Najszybciej blednie ustawiony obd.ini. Masz fejsa na innym porcie niz ustawione w obd.ini.
