;EDIABAS 6.4.3 Configuration
[Configuration]
; EcuPath
; Description : ECU file path
; Default = .
EcuPath = C:\EDIABAS\ECU
; SimulationPath
; Description : Simulation file path
; Default = .
SimulationPath = C:\EDIABAS\SIM
; TracePath
; Description : Trace file path
; Default = .
TracePath = C:\EDIABAS\TRACE
; CodeMapping
; Description : Character mapping file path
; Default = .
;CodeMapping = C:\EDIABAS\BIN\ansi2oem.tab
; TraceSize
; Description : Maximum size of each trace file [KB]
; Value : 0..32767
; Default = 1024
;TraceSize = 1024
; ApiTrace
; Description : Enable/Disable API/User trace
; Value : 0 = Trace disabled
; 1 = User trace
; 2 = User trace + time stamp
; 3 = User trace + time stamp + process id (Win32)
; 4 = Function trace
; 5 = Function trace + time stamp
; 6 = Function trace + time stamp + timing
; 7 = Function trace + time stamp + timing + process id (Win32)
; Default = 0
ApiTrace = 0
; IfhTrace
; Description : Enable/Disable IFH trace
; 1 = Trace enabled
; 2 = Trace enabled
; 3 = Trace enabled
; Default = 0
IfhTrace = 0
; SystemTraceSys
; Description : Enable/Disable system trace (runtime system)
; Trace levels 1..7
; Default = 0
SystemTraceSys = 0
; SystemTraceBip
; Description : Enable/Disable BIP trace (runtime system)
; Trace levels 1..7
; Default = 0
SystemTraceBip = 0
; SystemTraceIfh
; Description : Enable/Disable IFH system trace
; Trace levels 1..7
; Default = 0
SystemTraceIfh = 0
; SystemTraceNet
; Description : Enable/Disable network trace
; Trace levels 1..7
; Default = 0
SystemTraceNet = 0
; BipDebugLevel
; Description : BIP debug level of ECU files
; Value : 0..32767
; Default = 0
BipDebugLevel = 0
; UbattHandling
; Description : Ubatt ON/OFF handling
; Value : 0 = Ubatt ON/OFF: No EDIABAS error
; 1 = Ubatt ON/OFF: EDIABAS error
; Default = 1
UbattHandling = 0
; IgnitionHandling
; Description : Ignition ON/OFF handling
; Value : 0 = Ignition ON/OFF: No EDIABAS error
; 1 = Ignition ON/OFF: EDIABAS error
; Default = 1
IgnitionHandling = 0
; TaskPriority
; Description : EDIABAS process/thread priority (only Win32/16)
; Value : 0 = Optimal EDIABAS performance = 8
; 1 = Minimal EDIABAS performance
; 10 = Maximal EDIABAS performance
; Default = 0
TaskPriority = 0
; LoadWin32
; Description : Map EDIABAS Win16 calls to EDIABAS Win32
; Value : 0 = Win16/32 Mapping disabled (Win16-->Win16)
; 1 = Win16/32 Mapping enabled (Win16-->Win32)
; Default = 0 for Windows 9x/Me
; Default = 1 for Windows NT4/2000/XP
;LoadWin32 = 0
; SystemResults
; Description : Enable/Disable system results (ubatt/ignition/jobstatus)
; Value : 0 = Disable system results
; 1 = Enable system results
; Default = 1
SystemResults = 1
; RetryComm
; Description : Repeat failed communication automatically (1x)
; Value : 0 = Retry disabled
; 1 = Retry enabled (1x)
; Default = 1
RetryComm = 1
; Simulation
; Description : Enable/Disable ECU simulation
; Value : 0 = Simulation disabled
; 1 = Simulation enabled
; Default = 0
Simulation = 0
; Interface
; Description : Connected diagnosis interface
; Default = EDIC
Interface =STD:OBD
; Additional information (in German) :
; Bitte beachten: Der HW-Treiber fuer das Interface muss installiert sein!
; Interface = STD:OBD
; Beschreibung : Serieller Pegelwandler (Nachfolger von ADS / Anschluss an OBD-Dose)
; Installation : \EDIABAS\HARDWARE\OBD\ODBSETUP (nur noetig fuer WIN NT4, WIN 2000, WIN XP)
; INI-Datei : OBD.ini nur benutzt wenn im Windows-Verzeichnis
; Unterstuetzung : WIN3.xx : Nein
; WIN95,98 16-Bit : Ja
; WIN95,98 32-Bit : Ja
; WIN NT 4.0 : Ja
; WIN XP : Ja
; Interface = STD:FUNK
; Beschreibung : Funk-Diagnose Interface MDA von Fa. Siemens
; Installation : keine
; INI-Datei : FUNK.INI
; Unterstuetzung : WIN95,98 16-Bit : Ja
; WIN NT 4.0 : Ja
; WIN XP : Ja
; Interface = ADS
; Beschreibung : Serieller Pegelwandler (Anschluss an Diagnose-Dose)
; Installation : \EDIABAS\HARDWARE\ADS\ADS32\ADSSETUP (nur fuer WinNT4 noetig)
; INI-Datei : keine
; WIN95,98 32-Bit : Nein
; WIN NT 4.0 : Ja
; WIN XP : Ja
; Interface = KBUS
; Beschreibung : Serieller Pegelwandler (Anschluss direkt an K-Bus oder I-Bus)
; INI-Datei : keine
; WIN NT 4.0 : Ja
; WIN XP : Ja
; Interface = EDIC
; Beschreibung : Serielles , PCMCIA , PC-Card Interface von Fa. Softing
; Installation : \EDIABAS\HARDWARE\EDIC\SETUP.EXE
; INI-Datei : EDICFW.INI, EDICHW.INI
; WIN NT 4.0 : Ja
; WIN XP : Ja
; Interface = EDICC
; Beschreibung : EDIC-Card C oder EDIC-Card 2 CAN-Interface von Fa. Softing
; INI-Datei : XEDICC.INI
; WIN NT 4.0 : Ja
; WIN XP : Ja
; Interface = STD:CAN
; Beschreibung : PCMCIA CAN-Interface CanCardX von Fa. Vector
; Installation : keine (ausser Installation der CAN-Karte)
; INI-Datei : CANRTTP.INI
; Unterstuetzung : WIN95,98 16-Bit : ?
; WIN95,98 32-Bit : ?
; WIN NT 4.0 : Ja
; WIN XP : ?
; Ansprechpartner: Hr. Jusko
; Telefon : +49-(0)89/382-35891 (Hotline)
; email : [email protected] (Hotline)
; Interface = STD:ADS4MOST
; Beschreibung : Most-Interfaces von Fa. Oasis
; Installation : keine (ausser Installation der Oasis-Karte)
; INI-Datei : ADS4MOST.INI
; WIN NT 4.0 : Ja
; WIN XP : Ja
; Ansprechpart.: Hr. Rowedder
; Telefon : 089 / 382-29159
; Interface = REMOTE
; Beschreibung : Anbindung eines EDIABAS-Interfaces über TCP/IP
; Installation : Anpassung der Einträge in [TCP] auf beiden Seiten (ins.: RemoteHost, Port)
; INI-Datei : keine
; Unterstuetzung : WIN95,98 16-Bit : Nein
; WIN NT 4.0, XP : Ja
; WIN XP : Ja
; Sonderfall : Interface OPPS
; Interface = REMOTE:name
; INI-Datei : REMOTE.INI (insbesondere für Parallelbetrieb notwendig)
; In REMOTE.INI stehen unter [name] spezif. Einstellungen(z.B.: RemoteHost, Port)
; WIN XP : Ja
; NetworkProtocol
; Description : Network protocol
; Default =
NetworkProtocol = TCP
;TCP/IP Configuration
[TCP]
; RemoteHost
; Description : server address/name
; Default =
RemoteHost = 192.168.68.1
; Port
; Description : IP communication port
; Value : 1000 < port < 30000
; Default =
Port = 6801
;TimeoutConnect
; Description : Timeout for establishing the connection
; Default = 5000
TimeoutConnect = 2000
;TimeoutReceive
; Description : Timeout for receiving a message
; Default = 5000
TimeoutReceive = 2000
;TimeoutFunction
; Description : Timeout for a long function
; Default = 59000
TimeoutFunction = 10000
;DisconnectOnApiEnd
; Description : Enable/Disable Disconnection with function call ApiEnd
; Value : 0 = Disconnection disabled
; 1 = Disconnection enabled
; Default = 0
;DisconnectOnApiEnd = 1
;InitCmd
; Description : Initialization command (normally for OPPS)
; Default =
;InitCmd0 = FE,04,00,03,01
;InitCmd1 = FD,05,00,03,01
; End Of File EDIABAS.ini
PRÓBOWAŁEM TEŻ W DIS Z IP 192.168.68.30
[OBD]
Port=Com1
TRACELEVEL = 0x00000000
HARDWARE=OBD
RETRY=ON
MODE=NORMAL
;OBD-Stecker OBD
;OBD-Stecker am USB->Seriell-Adapter USB
;alte ADS-Hardware ADS
;Tracelevel=0xFFFFFFFF
;Tracelevel=0xF0000000
;Tracelevel=0x0000FFFF
; Bit 0 = Funktionsaufruf
; Bit 1 = io Ergebnis
; Bit 2 = nio Ergebnis
; Bit 3 = Detailinfos
; Nibble 0 = readchar_wait
; Nibble 1 = main
; Nibble 2 = cmd
; Nibble 3 = obd
; Nibble 4 = send_and_receive_...
; Nibble 5 = read_telegram_...
; Nibble 6 = send_telegram
; Nibble 7 = SendData
;[uNIT_x] x = A, B, ...,Y, Z, 0, 1, .., 8, 9
;Port = Com1 COM1 .. COM9
;TRACELEVEL = 0x00000000 0x00000000 .. 0xFFFFFFFF
;RETRY = OFF OFF, ON
;MODE=NORMAL NORMAL, KBUS
;HARDWARE=OBD OBD, USB, ADS
[uNIT_A]
Port=Com1
Hardware=OBD
RETRY=ON
MODE=NORMAL
[uNIT_B]
Port=Com2
Hardware=OBD
[uNIT_C]
Port=Com3
Hardware=OBD
[uNIT_D]
Port=Com4
Hardware=OBD
[uNIT_E]
Port=Com5
Hardware=OBD
[uNIT_F]
Port=Com6
Hardware=OBD
[uNIT_G]
Port=Com7
Hardware=OBD
[uNIT_H]
Port=Com8
Hardware=OBD
[uNIT_I]
Port=Com9
Hardware=OBD
[uNIT_J]
Port=Com10
Hardware=OBD
[uNIT_K]
Port=Com11
Hardware=OBD
[uNIT_L]
Port=Com12
Hardware=OBD
[uNIT_M]
Port=Com13
Hardware=OBD
[uNIT_N]
Port=Com14
Hardware=OBD
[uNIT_O]
Port=Com15
Hardware=OBD
  • Odpowiedzi 3,2 tys.
W ediabas mam tak samo, ale w obd nie mam linijki z TRACELEVEL = 0x00000000
i jeszcze inaczej masz
[OBD]
Port=Com1
Hardware=USB
RETRY=ON
[uNIT_A]
Port=Com2
Hardware=OBD
[uNIT_B]
... ale nie wiem czy to ma jakies znaczenie
jc78...dodam tyle że sprawdziłem wczoraj na sprzecie warsztaowym, takim profesjonalnym testerz..ale nie boscha...i łaczy sie ze wszystkim wiec wina w naszych fejsach...trzeba byc twardym...pomecze w przyszłym tygodniu..a jak nie pojdzie to sie moze spikniemy jakos..pozdro
[OBD]
Port=Com1
Hardware=USB
RETRY=ON
[uNIT_A]
Port=Com2
Hardware=OBD
[uNIT_B]
Te róznice nie wpływają na połączenie póki co.. dalej gł komunikat to brak połączenia z controlunit:(
póki co walczymy:) nie widze problemu mozna sie spotkac zawsze co dwie głowy to nie jedna:)
pozdro
Zainstalowałem nowszą wersję eiabas i inpa.. Teraz w inpie moge zobaczyc błędy silnika i parę podstawowych parametrów, ale nie mam żadnego dostępu do modułów samochodu..
Dalej nie rozpoznaje auta idac normalna drogą, NCS również go nie widzi.. W DIS mogę zerknąc tylko w sekcję DDE(poprzez wybór manualny auta) i to byłoby tyle. Kodowanie też nie działa..
Macie jakieś pomysły czy programowo można jakoś na to poradzić czy fejs lipny??? Chociaż z tego co piszecie to niektórzy posiadają taki sam fejs i jakoś to działa.
Mam ten: http://allegro.pl/show_item.php?item=1205977347
Mam jeszcze jeden temat, parę dni temu wymieniłem świece i z tego co widzę to komp wywala mi taki błąd:
GLOW PLUG ON 5 ZILINDER AKTIVATION, czy to oznacza że swieca cały czas jest grzana? Może to być wina sterownika świec? Można jakoś to sprawdzić(programowo pewnie ale niestety u mnie póki co lipa)??
Pozdro.
udało się połączyć z autem, z silnikiem można się połączyć - jednak nie mogę się połączyć z AIRBAG błąd IFH-0009 :roll: w czym może być problem?
i znowu program się posypał po jego poprawnym działaniu chciałem zrobić update do nowszej wersji bo nie chciał się łączyć z airbag i teraz znowu błąd 0003... :shock:
czy przy każdej instalacji programu musi być dodawanie zmiennej środowiskowej? robię wszystko tak jak jest opisane w PL instrukcji od nerwus :?
czy przy każdej instalacji programu musi być dodawanie zmiennej środowiskowej? nerwus :?
Nie, wpisujesz ją tylko raz, chyba że stawiasz system od nowa.
IFH-003 to fizyczny problem z fejsem (albo zala konfiugracja albo padniety fejs). IFH-009 to jak mi sie wydaje z opisem "no respons from control unit" i tutaj wina bardziej albo w INPA lub sterowniku w aucie. Warto ten sam sterownik sprobawac dis'em a dla magiokow tool32 + skrypty (z inpa lub dis ewentualnie ista/p).
To po gratulowac sprzedawcy opisu. Obd.ini idzie do C:\Windows . Jezeli masz fejsa na USB to bez tego pliku w tej lokalizacji zapomnij ze ruszy.
U mnie to samo. Do jakiego dokładnie folderu w c:\windows?
Czy to może mieć coś wspólnego z takim komunikatem gdy zaczyna pracowac EDIABAS Server?:
http://i4.photobucket.com/albums/y121/LUCZAR/Inne/bd_INPA.jpg
I przy okazji może głupie dla was pytanko (zaczynam dopiero razkować :roll: ), jak odinstalować EDIABAS + skłądniki? Nie ma nigdzie "uninstall". Chciałem przeinstalować, bo zassałem z innego źródła innego EDIABAS.
Odpal C:\EDIABAS\Hardware\OBD\OBDSetup.exe to dla xp napewno zniknie. Dla vista i wyzej trzeba dodac wpisy recznie do rejestru. Pisalem juz o tym na forum.
Unistal nie ma normalnie recznie wywal katalogi z c ewentualnie odpal drugi instalator to sam zapyta czy usunac/aktualizowac.
Koledzy spędziłem 3 wieczory szukając tego za....nego wpisu do rejestru Visty i na forach polskich i angielskich i lipa :( Kolega Nerwus rzeczywiscie to opisywał, ale w linkach zewnętrznych które już dawno wygasły.
Czy mógłby jakiś "dobry samarytanin" opisać mi krok po kroku co, jak i gdzie zmienić w tym rejestrze? Oraz drugie pytanko, obd.ini podmieniamy w BIN czy tylko wrzucamy go do c:\windows\.
Zrobiłem Ci gotowca, wystarczy wyklikać i wpisy dodadzą się do rejestru.
http://rapidshare.com/files/419857527/OBDsetup.rar
obd.ini do %windir% czyli zazwyczaj C:\WINDOWS
:D :D :D :D Wieeeeelkie dzięki!!!!!! Działa teraz bez zająknięcia!!!! :dance: :dance: Dziękuję, że pomogłeś.
Podepne sie pod temat. Probuje caly dzien scaignac skads inpe ale wiekszos rapidshare'owych plikow na jakie trafiam juz nie dziala. Te linki na forum tez nie dzialaja juz. Nawet udalo mi sie sciagnac z tej strony: http://peb.pl/literatura-programy/397307-rapidshare-bmw-inpa-ncs-expert.html
Ale to jest w trzech czesciach i za nic nie chce sie poprawnie rozpakowac. Czy ktos moglby litosciwie wrzucic jakis sprawdzony link, ktory bedzie dzialal?
O Tempora! O Mores!
http://rapidshare.com/files/420006303/inpa_5_0_2_10.0.0.4.rar
A rozpakowujesz to rarem ? Pliki z tej strony zazwyczaj są ok wiec zakładam że coś robisz nie tak, ściągnij winrara i zainstaluj, powinno pomóc.
Bardzo dziekuje kolegom!
Sprawdze jak tylko dotre do domu po pracy. Rozpakowywalem rarem wczesniej i nie dalo rady. Wygladalo na to ze te wszystkie trzy czesci zawieraja dokladnie to samo.
Bede z tym nowym linkiem walczyl dzis wieczorem.
Jeszcze raz bardzo dziekuje.
O Tempora! O Mores!
Witam. Mam INPA 5.0.2 i nie mam w opcjach auta X5 E53... Jaka jest najnowsza wersja i skąd mógłbym ja pobrać?
Kolejna sprawa, czy w X5 E53 2002r można odblokować programowo oglądanie tv pocdzas jazdy + uruchomienie webasta jako grzanie wnętrza (jest tylko przewietrzanie)? Jesli tak to w jaki sposób?
Mam pytanie , stawiam pierwsze kroki w użytkowaniu programu INPA i mam pytanie czym różni się w dziale ERROR , zakładka READ EM od zakładki READ IM bo np w zakładce RAED EM niemam żadnych błędów , a w zakładce READ IM mam jeden błąd w skrzyni widoczny na zdjęciu. Co oznacza zakładka READ IM ?? i Co oznacza błąd który się tam znalazł . Z góry dziękuję za odpowiedzi
http://img440.imageshack.us/img440/2482/bdkopia.jpg
Uploaded with ImageShack.us
I jeszcze jedno pytanko odnośnie tych dwóch błedów wyskakują podczas skanu całego auta czego dotyczą bo nawet niewiem jakie to moduły co oznaczają te skróty MOSTGW E18F i KBM A43E i gdzie w jakich modułach szukać rozwiązania
http://img821.imageshack.us/img821/6769/41855330.jpg
Odblokowanie funkcji TV podczas jazdy nie wymaga Interfejsu, tzn. robi się to bez podłączania kompa. A masz webasto? Bo webasto i funkcja "Rest" (przewietrzanie) to cakiem dwie różne sprawy.
Ręcznie robiłem tak:
1. Włącz zapłon do pozycji II
2. wejdź w tryb TV
3. Wejdź w ustawienia (settings)
4. wejdź w kontrast (contrast)
5. gdy będziesz widział ustawiania kontrastu dla koloru zielonego, wciśnij przycisk potwierdzenia (knob ??) i trzymaj go wciśnięty
6. wyłącz zapłon (przycisk cały czas wciśnięty)
7. odczekaj 8-10 sek (czas musi być w tym przedziale)
8. puść przycisk
9. ponownie włącz zapłon
Niestety nie działa, albo robię coś nie tak.
ad.1 Zapłon i pozycja II to znaczy że świecą kontrolki czy tylko radio?
ad.6 Wyłączenie zapłonu to całkowite (radio gaśnie) czy tylko wyłączenie kontrolek licznika, a radio działa?
Webasto mam pod maską jako urządzenie, ale ono w chwili obecnej działa jako dogrzewanie silnika. Jest urządzenie jak napisałem, łapanie powietrza z nadkola jest i odprowadzenie spalin pod drzwi kierowcy też jest ;)
Więc jak to wszystko zorbić kolego? Już nie wspomnę o uruchomieniu światełek dziennych i innych tam dupereli, które fajnie by było samemu zrobić ;)
webasto masz jako dogrzewanie silnika zapewne .... sprawdź czy w tej 6-pinowej kostce co jest do webasto pin nr.1 jest zajęty .....jeśli nie jest to wystarczy dołożyć centralkę z pilotem i przekaźnik do włączania climatronica i masz ogrzewanie postojowe!
Chiptuning Łódź
