  • Odpowiedzi 2,4 tys.
koledzy mam problem z sss!Mam fejs na usb http://allegro.pl/interfejs-bmw-inpa-k-d-can-ncs-expert-dis-sss-i1311200944.html podmieniam rózne changes i caly czas mam brak komunikacji ze swoja e60 z 2005r.Plik obd.ini
[OBD]
Port=Com3
Hardware=STD:OBD
RETRY=ON
;Tracelevel=0xFFFFFFFF
;Tracelevel=0xF0000000
;Tracelevel=0x0000FFFF
; Bit 0 = Funktionsaufruf
; Bit 1 = io Ergebnis
; Bit 2 = nio Ergebnis
; Bit 3 = Detailinfos
; Nibble 0 = readchar_wait
; Nibble 1 = main
; Nibble 2 = cmd
; Nibble 3 = obd
; Nibble 4 = send_and_receive_...
; Nibble 5 = read_telegram_...
; Nibble 6 = send_telegram
; Nibble 7 = SendData
[uNIT_A]
Port=Com1
Hardware=STD:OBD
[uNIT_B]
Port=Com2
Hardware=STD:OBD
[uNIT_C]
Port=Com3
Hardware=STD:OBD
[uNIT_D]
Port=Com4
Hardware=STD:OBD
plik ediabas ini
;EDIABAS 6.4.3 Configuration
[Configuration]
; EcuPath
; Description : ECU file path
; Default = .
EcuPath = C:\EDIABAS\Ecu
; SimulationPath
; Description : Simulation file path
; Default = .
SimulationPath = C:\EDIABAS\SIM
; TracePath
; Description : Trace file path
; Default = .
TracePath = C:\DiagProg\Trace
; CodeMapping
; Description : Character mapping file path
; Default = .
;CodeMapping = C:\EDIABAS\BIN\ansi2oem.tab
; TraceSize
; Description : Maximum size of each trace file [KB]
; Value : 0..32767
; Default = 1024
TraceSize = 5120
; ApiTrace
; Description : Enable/Disable API/User trace
; Value : 0 = Trace disabled
; 1 = User trace
; 2 = User trace + time stamp
; 3 = User trace + time stamp + process id (Win32)
; 4 = Function trace
; 5 = Function trace + time stamp
; 6 = Function trace + time stamp + timing
; 7 = Function trace + time stamp + timing + process id (Win32)
; Default = 0
ApiTrace = 0
; IfhTrace
; Description : Enable/Disable IFH trace
; 1 = Trace enabled
; 2 = Trace enabled
; 3 = Trace enabled
; Default = 0
IfhTrace = 0
; SystemTraceSys
; Description : Enable/Disable system trace (runtime system)
; Trace levels 1..7
; Default = 0
SystemTraceSys = 0
; SystemTraceBip
; Description : Enable/Disable BIP trace (runtime system)
; Trace levels 1..7
; Default = 0
SystemTraceBip = 0
; SystemTraceIfh
; Description : Enable/Disable IFH system trace
; Trace levels 1..7
; Default = 0
SystemTraceIfh = 0
; SystemTraceNet
; Description : Enable/Disable network trace
; Trace levels 1..7
; Default = 0
SystemTraceNet = 0
; BipDebugLevel
; Description : BIP debug level of ECU files
; Value : 0..32767
; Default = 0
BipDebugLevel = 0
; UbattHandling
; Description : Ubatt ON/OFF handling
; Value : 0 = Ubatt ON/OFF: No EDIABAS error
; 1 = Ubatt ON/OFF: EDIABAS error
; Default = 1
UbattHandling = 0
; IgnitionHandling
; Description : Ignition ON/OFF handling
; Value : 0 = Ignition ON/OFF: No EDIABAS error
; 1 = Ignition ON/OFF: EDIABAS error
; Default = 1
IgnitionHandling = 0
; TaskPriority
; Description : EDIABAS process/thread priority (only Win32/16)
; Value : 0 = Optimal EDIABAS performance = 8
; 1 = Minimal EDIABAS performance
; 10 = Maximal EDIABAS performance
; Default = 0
TaskPriority = 0
; LoadWin32
; Description : Map EDIABAS Win16 calls to EDIABAS Win32
; Value : 0 = Win16/32 Mapping disabled (Win16-->Win16)
; 1 = Win16/32 Mapping enabled (Win16-->Win32)
; Default = 0 for Windows 9x/Me
; Default = 1 for Windows NT4/2000/XP
;LoadWin32 = 0
; SystemResults
; Description : Enable/Disable system results (ubatt/ignition/jobstatus)
; Value : 0 = Disable system results
; 1 = Enable system results
; Default = 1
SystemResults = 1
; RetryComm
; Description : Repeat failed communication automatically (1x)
; Value : 0 = Retry disabled
; 1 = Retry enabled (1x)
; Default = 1
RetryComm = 1
; Simulation
; Description : Enable/Disable ECU simulation
; Value : 0 = Simulation disabled
; 1 = Simulation enabled
; Default = 0
Simulation = 0
; Description : Connected diagnosis interface
; Default = STD:OBD
Interface = STD:OBD
; Additional information (in German) :
; Bitte beachten: Der HW-Treiber fuer das Interface muss installiert sein!
; Interface = STD:OBD
; Beschreibung : Serieller Pegelwandler (Nachfolger von ADS / Anschluss an OBD-Dose)
; Installation : \EDIABAS\HARDWARE\OBD\ODBSETUP (nur noetig fuer WIN NT4, WIN 2000, WIN XP)
; INI-Datei : OBD.ini nur benutzt wenn im Windows-Verzeichnis
; Unterstuetzung : WIN3.xx : Nein
; WIN95,98 16-Bit : Ja
; WIN95,98 32-Bit : Ja
; WIN NT 4.0 : Ja
; WIN XP : Ja
; Interface = STD:FUNK
; Beschreibung : Funk-Diagnose Interface MDA von Fa. Siemens
; Installation : keine
; INI-Datei : FUNK.INI
; Unterstuetzung : WIN95,98 16-Bit : Ja
; WIN NT 4.0 : Ja
; WIN XP : Ja
; Interface = ADS
; Beschreibung : Serieller Pegelwandler (Anschluss an Diagnose-Dose)
; Installation : \EDIABAS\HARDWARE\ADS\ADS32\ADSSETUP (nur fuer WinNT4 noetig)
; INI-Datei : keine
; WIN95,98 32-Bit : Nein
; WIN NT 4.0 : Ja
; WIN XP : Ja
; Interface = KBUS
; Beschreibung : Serieller Pegelwandler (Anschluss direkt an K-Bus oder I-Bus)
; INI-Datei : keine
; WIN NT 4.0 : Ja
; WIN XP : Ja
; Interface = EDIC
; Beschreibung : Serielles , PCMCIA , PC-Card Interface von Fa. Softing
; Installation : \EDIABAS\HARDWARE\EDIC\SETUP.EXE
; INI-Datei : EDICFW.INI, EDICHW.INI
; WIN NT 4.0 : Ja
; WIN XP : Ja
; Interface = EDICC
; Beschreibung : EDIC-Card C oder EDIC-Card 2 CAN-Interface von Fa. Softing
; INI-Datei : XEDICC.INI
; WIN NT 4.0 : Ja
; WIN XP : Ja
; Interface = STD:CAN
; Beschreibung : PCMCIA CAN-Interface CanCardX von Fa. Vector
; Installation : keine (ausser Installation der CAN-Karte)
; INI-Datei : CANRTTP.INI
; Unterstuetzung : WIN95,98 16-Bit : ?
; WIN95,98 32-Bit : ?
; WIN NT 4.0 : Ja
; WIN XP : ?
; Ansprechpartner: Hr. Jusko
; Telefon : +49-(0)89/382-35891 (Hotline)
; email : [email protected] (Hotline)
; Interface = STD:ADS4MOST
; Beschreibung : Most-Interfaces von Fa. Oasis
; Installation : keine (ausser Installation der Oasis-Karte)
; INI-Datei : ADS4MOST.INI
; WIN NT 4.0 : Ja
; WIN XP : Ja
; Ansprechpart.: Hr. Rowedder
; Telefon : 089 / 382-29159
; Interface = REMOTE
; Beschreibung : Anbindung eines EDIABAS-Interfaces über TCP/IP
; Installation : Anpassung der Einträge in [TCP] auf beiden Seiten (ins.: RemoteHost, Port)
; INI-Datei : keine
; Unterstuetzung : WIN95,98 16-Bit : Nein
; WIN NT 4.0, XP : Ja
; WIN XP : Ja
; Sonderfall : Interface OPPS
; Interface = REMOTE:name
; INI-Datei : REMOTE.INI (insbesondere für Parallelbetrieb notwendig)
; In REMOTE.INI stehen unter [name] spezif. Einstellungen(z.B.: RemoteHost, Port)
; WIN XP : Ja
; NetworkProtocol
; Description : Network protocol
; Default =
NetworkProtocol = TCP
;TCP/IP Configuration
[TCP]
; RemoteHost
; Description : server address/name
; Default =
RemoteHost = 192.168.68.1
; Port
; Description : IP communication port
; Value : 1000 < port < 30000
; Default =
Port = 6801
;TimeoutConnect
; Description : Timeout for establishing the connection
; Default = 5000
TimeoutConnect = 2000
;TimeoutReceive
; Description : Timeout for receiving a message
; Default = 5000
TimeoutReceive = 2000
;TimeoutFunction
; Description : Timeout for a long function
; Default = 59000
TimeoutFunction = 10000
;DisconnectOnApiEnd
; Description : Enable/Disable Disconnection with function call ApiEnd
; Value : 0 = Disconnection disabled
; 1 = Disconnection enabled
; Default = 0
;DisconnectOnApiEnd = 1
;InitCmd
; Description : Initialization command (normally for OPPS)
; Default =
;InitCmd0 = FE,04,00,03,01
;InitCmd1 = FD,05,00,03,01
; End Of File EDIABAS.ini
INPA DIS chodza prawidłowo w disie api tet ok łączy sie z autem inpa również
DZIAŁA!!! E60 dziala z progmanem na plikach "changes xdrive" który emuluje głowice OPS potrzebną do komunikacji z autem.Mam tylko jeden dylemat czy pójdzie mi aktualizacja CCC?Czy ktos moze juz robił aktualizacje moduł CCC Progmanem V32 z emulowaną głowicą OPS?
albo ja cos zle robie albo juz sam niewiem..mam Inpe chodzi bez problemow:) sciaglem DISa z http://forums.bimmerforums.com/forum/showthread.php?t=1374483 - tzn to jeden z wielu ktorych sciaglem i lezy bezuzytecznych .. krotko .. prosil bym o pomoc bo naprawde nie moge sobie poradzic kogos zeby w jednym zdaniu napisal - PROGRAM+versja jak np VM itp ktore bede potrzebowal a ma u siebie i chula.. raz udalo mi sie juz ze zabaczylem panel DIS ale jak dobrze pamietam chcial jakies haslo przy instalacji :(
[OBD]
Port=Com3
Hardware=STD:OBD
RETRY=ON
; Nibble 1 = main
; Nibble 2 = cmd
; Nibble 3 = obd
[uNIT_A]
Port=Com1
Hardware=STD:OBD
[uNIT_B]
Port=Com2
Hardware=STD:OBD
[uNIT_C]
Port=Com3
Hardware=STD:OBD
[uNIT_D]
Port=Com4
Hardware=STD:OBD
Troszke ciezko w to uwierzyc szczegolnie ze Twoj obd.ini nie jest poprawny. Hardware moze miec ustawienie = OBD lub USB lub ADS ale nie STD:OBD.
Zadne haslo nie jest potrzebny przy instalacji DIS. Jezeli mowisz o hasle przy wejsciu do ukrytego menu pod "touch pad calibration" to jest ono rowne nr dealera jaki wybrales przy instalacji bazy. Jezeli idziesz wedlug standardu to bedzie to "12345".
To sa pliki zczytane z ediabas i obd.ini z windowsa ,moze dlatego tak jest że mam viste.Własnie teraz instaluje od nowa inpe i również w ediabas tworza sie wpisy STD:OBD nie samo OBD.Jak mi nie wierzysz to moge ci screany z Progmana wrzucićz mojej E60!
Ale ja mowilem o pliku obd.ini nie ediabas.ini. Nic tutaj vista nie ma wspolnego z zawartoscia plikow.
Jak dziala to bardzo dobrze ale pisz konkretnie bez wprowadzania w blad ustawieniami. Instalacja SSS sprawia duzo klopotow na forum i bez tego.
wkoncuu zaintalowana!!!hm podziekowania dla nerwusa za filmiki z intalacja EasyDIS_v44_base i GT1 .. mialem tam malutkie problemy np: przy pierwszym botowaniu ale niektore posty na forum pomogly :)
Przymierzam się do kupienia interfejsu do BMW
Oprócz kabla (który pasuje do wszystkich samochodów marki BMW -z tego co wiem)
potrzebuję program do komputera czy w tym przypadku jest podział na diesel - benzyna albo rodzaj silnika np 2,5 tds ?
Czym kierować się przy zakupie ?
Cena jest znacząca?
(nie chcę przepłacić )
Kolego power20 masz nie uzupełniony profil, model auta, nie piszesz do jakiego auta chcesz fejs więc skąd mamy wiedzieć czego szukasz. Nie ma fejsów pod wszystkie BMW. Stare nie czytają D-CAN a nowe ADS więc skup się i pisz dokładnie o co Ci chodzi.
Krzysztof
a co w tym dziwnego ze e90 chce kodowac disem, dla mnie dis jest bardziej czytelny i intuicyjny w kodowaniu niz NCS
pozdro
jeszcze jedno w disie diagnoza jest po angielsku a kodowanie po niemiecku dziwne to moze ktos wie co jest przyczyna albo jak zmienic z niemieckiego na ang w kodowaniu
chcialbym jeszcze dodac ze jak wejde w glowice to nie ma tam nic, same puste pola (wczesniej podczas instalowania DISa za 1wszym razem byla moja nazwa laptopa wraz z numerem IP) ale w polaczeniu karta jest widoczna. Pomimo tego diody mam wlaczone. Probowalem zmienic na fister i vm off ale wtedy nie dziala nawet diagnostyka. API test przechodzi ok. W diagnostyce automatycznie wykrywa auto i moduly a kodowac nie moge. Na print screenie widac ze antyvirus ON ale mialem go wylaczonego. Co moze byc przyczyna. Pacjent to E90.
pozdro
pozdro
Jak rozłączysz głowice w disie to znów się pojawi nazwa twojego kompa,
jak włączysz to nazwa kompa zniknie, to normalne..
Zaktualizowanym NCS-em lub Progman-em powinno polecieć bez problemu.
pozdro
Postaw sobie progmana v32 a nie starego disa sie czepiłes
do tego co chce zrobic nie chce mi sie pobierac sss
dis jest prosty i intuicyjny w obsludze i chcialbym DISem robic kodowanie tym bardziej ze mam go juz zainstalowanego i diagnostyka smiga
pozdro
No i stało się ista/p na zwykłym laptopie. Pracuje z OPS/OPPS/ICOM/OBD/DCAN.
Na dniach wstawię screnny z działania dla ciekawskich.
Teraz czekamy na ista/d (prace już na ukończeniu - brakuje prostego mechanizmu update).
Według ETK to najnowszy to 7522322 i jest z dnia 01.08.2005,
jak się mylę niech ktoś mnie poprawi.
BMW E60 530xd :)
