Witam od niedawna zaczęła się swiecic kontrolka dde błąd jaki wyskakuje p14a1 co to może być czy można z tym jedzic
P14A1 – BMW
Leave a Comment / OBD-II Trouble Codes
Code : P14A1
Make : BMW
Description : P14A1 BMW Exhaust Gas Back Pressure Sensor Short Circuit To Positive
Possible causes :
– Faulty Exhaust Gas Back Pressure Sensor
– Exhaust Gas Back Pressure Sensor harness is open or shorted
– Exhaust Gas Back Pressure Sensor circuit poor electrical connection
Solutions :
– Carry out a Reset via CarDiag
– Choose a better quality fuel
– Check that the tank cap is securely closed
– Check the oil level and add more if it is lower than MAX
– Restart an Automatic diagnostic via CarDiag
– If the fault persists, you can check the “Possible causes” listed above : visually inspect (by yourself (tutorials to come) or by a professional) the wiring harness and the associated connectors, check for damaged components, and look for broken, bent, pushed, or corroded connector pins.
Pozdrawiam,
deebee (Darek)
