i need help with Turbo BMW 120D E87 2004 Engine M47
Well hello everyone i am new on BimmerForum here,
well my problem is, my Turbo Blocked and i had to repair it soo i went to the Service they Repaired my Turbo and now the car turns on and drives but i always hear a wierd Sound on the car i think it comes from the Turbo its like bloop bloop
and main problem is the Turbo activates only when i press the Pedal twice to the buttom or if the RPM goes over 3000RPM and advice what should i do the service said its normal and i need to wait few days untill the car cleans it self >.<
btw the car was at service garage for 1month and 11days that means it dident turned on or drived till the spare parts of the turbine arriwed :S
i cleaned the air sensor intercoler sensor what should i do other soo i can fix it or is it normal :S pls help me out
Best regards
B.SH
new turbo is the solution.
Mój czarnuch
Drugi czarnuch-540i
E32 740IL
Kupię do e46 sedan przedlift:
- maskę cosmosschwarz 303
well my friend thats too easy just to change the turbo but the problem is i paid alot for it to repair it and to fix it
come back with complaint, turbo regeneration is a problem.
Mój czarnuch
Drugi czarnuch-540i
E32 740IL
