E36 wreszcie po bardzo długim czasie stanęło na własnych kołach
2YTYfcqyta74Cr8coce3EuFbgIX5t5q9sUAL_oPjZlZZ6KNSrBKRYEFnVITE5R3Wu6ZFSl_19cvxmL_Po-IwS_kD329W2RLSYTQpIbxE85nK7Nuq5BR1KcnAoD1vp64bYtrgY0kambJAaofKk8ZAHlz7wFZTvowV5-cpfJzEuOKo-SHql0sLhG4cSPyYXRUxyKqxQhj7Nnj2Yoe3BKFQ6-TYnQz5832ceRLGBKhx2l3JHAdDTja1uiuULL0dPw6IVr50luY7nD7tlE6qmo418A48scSyWydW_tUc9yRu6g1-QIT5kZzcx0sI2f36xKKUX_LVhPnQ22oJ2XyDTwWIoCaCtT4Mz4FTPoql81DA-kBoi50CAc7jE-LfqeAd1WeZ_UmRhUjUZQt_MItcgd2khCUUA9V6XJxef6SmT9PsRYDW2Q09Eonl3Sy-F57MGhUjZxRxWPlE4wLtG6mbNADQ5zDD2w38vJWAJEvs8j1FjhSwA2G01yhE04xyfDsY4Sje4Wu8iuHSA6cUXMAXJDfzOuvjOcFML-WLPPuh3-f3U79z7UxwY1TgqCei3vqKLhgpiPwcxaJeEJW5unybtvidQyoZQhoguwB7OFQPltcy9caKDGmNJkvAIacg-wgeijmxob9El2QYyGFuge2JJTNoCf2lZhkKOkWEytSpOEXcS7zH06ni_O-Jf2Ib3o7s-Hd5sM_xocKAhFt6Fw771JoozeEYNBXPFq4SEjfeD7XXtQBwWSCQ4XlNPeI=w960-h720-no?authuser=0
b1r6Yh5dBsSeKR5upzLf_WW2jLv7jQk3MS5n9xkA1H4Q8DcdlcaVhNMdnig1MiZrfTfzalGm1u2uw27yhhsMY1oZYOq6tzIpSsL2SxnC5vg05y9EJT0LmIHj10HR1AIaFIMVjCUMrWVeNLI5Ib2Y9CMTuAsFkTg6QtJFXAyBFqMzlx0O8aOmbVihasb8dfVeSAXog1a0RwKSR_9fp0MoFDz_5z37CRpGkMzDVm9pOwsnRFTETG3XCy9WZCRCZM2nBEGkB6K2Xb2ulodFPSOPD4nEyv_YXkPvNEgJooV7WddF79xPHxu8r2TdQpFgdlKTWGMzeAHdY1cobjZkRFcszXFV1r8zPXRg1MZxNxOgxGds1p-WG8JNJgYF8UfxQSuMRwvNBYABq9uDWWf5ELIQPz1ZW0eVuw_VzTJWw-zF5j9Bz7-YPXZzA7u-lEZJnGsj8Su_kvXK74Jy0WLZMgxpYspxwxea_FMo4kyjxvy7MyyLwmHF4ukUU4hpSI9obDhlt6CP4oXRgXd6izj8SaL5risxHnosqQmhMMT1vnczyQ_MKacasQgH1NT2Ybca3SJtXYa46L6oBqoBSt6_2I_-Cd_JGFszTKxEY2yvlYUPLGHlmFWFcCIxpR5BIEXGMz3jHRINPt5gN6FZfcuGtgDWeC1GrLQbGB7SVDNJ9SbRCHtNe7DqoVCtemnkHwIe8fBkM5P23_0bnaURwTfBYa917n-rh9YsC9wCmJnQwFUPkERmDsEkJfFKifs=w960-h720-no?authuser=0
H6hq1Ed9QMW6gj0JQ_G2rbfXm0wYjeq6TXOPebQ_5P6Wnfw2LVu46VzaHaXbIYM2Pa8JfI3By16z3j25B3yrRjsQrbblAnJIc63O-ckn9ql-pFMynjlwV0dY5zDkkn4Oj1EMzu5qSSdPuagiDdHe6A-25a12vGaX3C-JBjp9HMnD9-sSKyWn7UwX_bOD_CfODkNtlY7CppZ35RuTsmN8Oayd8Y-5YceBxbM1RLNUzROHdK7K3vTn2CGE8iuON7o9PycNrIpvbMtaYRJsYJqoQyvdmaTK1UsV5D-u-2Tg-YZro9hISiZMvZDq4puwVwFio5kcHwQ_yEOuC7JyGAhWUuIteJleB8OBC8OXcSOepVEpdN49LveJLB_4e8ZvivBlTprmmbuACdnHQ8cQ79AjFu-6iIrdO5Sk5GuFhl3dKYq0UR-qzR0pIi3UIs80jXDiWTlS3QbgUFzsjVE5D53sU1xPcwyiI1-LhTwL08pUDqDmvjOM-ViqvST8Gdrp16yg4xxgpGvQfJGs_8Mycq05T6t6i2V0RHzePtaJz4cAtAqfW-tfvyiEJEdM9_mC8nDTlkAYH0lFRz7bpb8EH77EC1aQQY3Kexuza3uEN5_hra_j6msFIAWQDMQxO6mPu8HZTtXJwDBaM5-VPl4AhvsenYjA3Pc4pNB6GkUj5y8n58W_N19pPyiPbVOgR1Nq0l8f9rFQTRRYqnb1_-76ghZTf2oHYZ9sVf3wAfaUVi1zpAeKupZX-wAFi14=w633-h843-no?authuser=0
IJ3kCvhL8FW_I3DfyhfTscjkQsBwfTtiPc0TETSjgK4QB8Zjb4ux3DbiHuacw_cl1XFNLgaLBoZWEweNhPJn0F4ek4zSBQSnIYIUZMmiyGTjVrg09sYLW5UwVX17DVyWWcTga_OztG8G2QUcu94kH52sOTFp3RqQxsTp8R0QoQMWrU9cqLP7eH_NILndkfEXyr-YpwW6a_a8I28I-HRx6UPL6Z-CxDanV_5Eac_59l6C0CUXGZJqjNgau2GkwZLHzPAk2hT0JSrpNYmI3aEfQCSU9D_7skYdT1tY6l39KJM7X8nwf_F33yqNnWudJSCzVJUa_0wRdMpq3a56NyFNb3Ropduq241Yg2y14xOlsPh13CsAm8JJLBunASXBSLqSmggCSqyKPFUG9x887glMJwhymGGtUnC6z3zRbCrkTgRukQnJIv4suHzqchYOMwgYgZD1i2I3IbA01yaGKpilQ91cYrx1dlcqYlRL6AxLwO6eRSwRp1xEWLtbrfzeFJ7IoH6LiyC7kNR958vuAG5IzoUVlayIUWUxKju0Z8aPddWvPbfRVYcayLuq2Jq-4xG0ViWSMgRS1pnev7D2IXm-LYB_zm6UUEOpOc4wwVrAovjInd_m5mamBMC6QYR5zUsF7IfZkd5Yr0bNN0jufMw3Rlz-xeTMyTBwCybVri2kpqHunl29ebvqmOYeX2y4d_SgRYFysQp9P3eHwHmdbQkAqf94U_YHlc0mdOKEHAB_nUxAadnrNwVeZHY=w960-h720-no?authuser=0
Ogólnie nie jestem zadowolony. Felgi odebrałem (kozacka robota) i przymierzyłem do samochodu... Okazało się ze przednie felgi mają et13 i taką konstrukcje rotora, że zacisk od e46 nie siada. Musiałem dać na próbę dystans 15mm. To nie jest to czego oczekiwałem. Coś tam pomierzyłem i uda się zejść do dystansu 13mm bez kolizji zacisk-felga. W tylne nadkole można tico wrzucić. Regulacja skręcona na max, oczywiście na pewno siądzie jeszcze o 1cm może dwa. Będę kombinował z wyjęciem nakrętki kontrującej, albo całkiem usunę regulacje.
Felgi myślę, że stylistycznie dobrze siadły. Docelowo kapsle miałem oddawać do chromowania natryskowego, ale raczej dam je w kolor nadwozia i do tego znaczek ori rial czarny napis na srebrnym tle.
Pod wpływem frustracji zamówiłem dolot...
23FDbFPgUfyfS8JC3jY2pB5wp3bMLWJisp18JQbA380YxDSpZSf9M-tlVr-BHkY18IIJkYEFYHBG9wEA_uPK7-bL07y-rmmp_LjPuT0FueBHnn2ZFOESTBzK-9mPSaHriZ7f0zBGTnFz0D4nFXfs3hxNwbLrjkNK6lf8OTIFhgVe0jQNHPmh9slliZJmpL0KwI6UGW_qdm0svZ-jsIT_jkUdqhYqJp_ypPim5YFadczk95Od7OUzqraQNxtyzs30QwaBll9W-0j766ouRLac3RrrR6HKdOecJ3ObgH361H8MzGHNG6vgVtVTEaMvrJM3Pj-Xd-gUPge8hx1hOmwT6lf_KsEbcvWLB1ArBWRzrLF4cdS--8t3iTA3v0f0hn7ZVH4v2Cjn_M6foulZc8K9au97dZYOOWSEoe6EbbeJHGcK0R9ISjTV_7nitLROC48QnvQXcX-8gQXcCWNkcZM-FLn9qBdqRWDYcoaRkJTPitOrCFTHL4esoRXcgghTbQjwrItNvhqE660HO-2IGBqkhls-NBsPkbXjDyWgjj8cDq4MsSzPan0Gl-XEQEo0iiPQay0IS0QlCI4sX3hRnlWiY7w_wZr3jgGxtlZyP04yXa3ht1_YA7zOdLA9cwoOkCRw0gq-bYdDqtkrSMZWpCDdTeBhVOdgCzcGGaYPj7cFsCdYHX2gGC886w8kTdzeFCmWObr0L9mDyWgD32WsFKw2IIVPV2SE5vLnWEvbf37pHIpT6mfS9OSfMF0=w633-h843-no?authuser=0
Dedykowany rozmiar pod m54b30.
Przerobiłem układ paliwowy pod filtr z regulatorem.
Nic konkretnego poza tym nie zdziałałem. Mam zaciski na tył już pomalowane i do zmontowania na nowym tłoczku, pompa wspomy już gotowa do montażu i coś tam na krótko polutowałem wiązkę. W weekend zalewam paliwem i pale fure :D
Dokładnie, daj kapsle w kolor tak jak piszesz i oryginalny znaczek.
Felgi pasują :cool2:
Benzyna zamiast krwi...
  • 2 miesiące temu...
Tempo prac niestety spadło, ale cały czas idzie w prawidłowym kierunku.
Aktualnie działam, przy dorabianiu i doginaniu przewodów hamulcowych pod samochodem i na wahaczach. Równolegle układ paliwa pod samochodem na gotowo.
W linku filmik z testowego pierwszego odpalenia.
Ssący i wiązka silnika już ściągnięta, muszę poukładać kable. wprowadzić w wiązkę tempomat, klimę, czujnik wstecznego, czujniki sprzęgła itp.
  • 2 lata później...
Witam witam, jest parę aktualizacji :D
Kompot jeszcze nie jeździ, ale odpala i wreszcie jakoś brzmi :D
Temat wydechu zamknięty. Miał być Y-pipe i dopasowany końcowy, ale po rozmowach z Grześkiem z GTP zdecydowaliśmy jedyną rozsądną ścieżką, czyli albo grubo albo wcale. H-pipe i dwururka do samego końca na customowym tłumiku :D
Pacjent przygotowany do drogi ...
AMWts8ASR2c1UAXm3htU2gxQ6qoq0pKqs1ZlgAAA5XIr596uajocNhvCZYJXuctkGvYeH0e0AWXZmAaeBrgTtjBuNrZ9rs49XdPGhLn98H3nrcsp-9LmvVfRn3ePoExisEPByBHCNtyeTPDCOSNrKruUZn8t=w800-h387-no?authuser=0
Efekty wyprawy.
AMWts8Bmzpe2vbGzOYK1AfEa4xwN8VS1pwwcrsfbyNNqTjz5pmfAAEF6zDY4XIl1wfRJK8You58n4rxPGWO73WyB7bCu64_GZpQv1Gc44aVe5qFijqXqoib82LhgoSCqX7LAYrsVc1LnKm5Oxh4K7HP35iu7=w800-h450-no?authuser=0
AMWts8D5v6EArcyAT5tm26Srmf5j2afm2QdztDm9NPXsPVjYCgui9rEZCtMmTYhqY41uWpvVL_rbZWaIxP7sg3B2Rpu1Gj1Bi_hGSBlcj-BV3omYdj6n_vPDI6-F4aMEbHCP2CEnrRvbTVunOgIBupFcSybm=w800-h450-no?authuser=0
AMWts8AMGRR1pHSttIbkaTIggPKPojljP-sDjVIgkBtgctFELVCc3GvM8YCKiA6oBBqkzuf5rmzr-hBvK95W_ocPaVnqKk45-um5DkftTNZiCaebl-dvgz6lX-8MleT6PnzSYJTenMGYeW0YQXP5Z0Wy3Cpc=w800-h387-no?authuser=0
Dokupiłem parę niezbędnych gratów... Zegary VDO i czujniki, rozpórkę tył, kratki i plastiki itp.
AMWts8D_NFCanGdV8_7_8ra81EqZtyukqXQm2I5IFZLA5JblNKoSdwTrtFrryff997aXmCqmHc9_OJ4Y4Bdj5tjzKI4TOtCQZN-jnPfUESq_r76HEkGZ9BxPdoNwJFauTdg_6PRVnm0bXHoNnK6ssaza8Uae=w1024-h496-no?authuser=0
AMWts8DGqUhA2z9_6RFdD3cJ1IA0bGlkRIu44XZFzFpwfODLi-bnldojqsY0HjOfsgIpwybzFF6gVmp6K1POt3Zz4phOEKMOkprvTBY5o-p9ifRVdYEwh-jSS6KwTUpo-TK6x5G_bYGxaTyXPmx_JKi7CtD9=w800-h387-no?authuser=0
AMWts8AvtvMnZKt9n8tFWUld3-gH7vE9XKWNn0l6SdCL087CzuW9VBag36KTrE1QHaSUgKIQq9VD3pP3PZGFCEF5KrGfGBjpl_ZqsYZZrJfbATBaURe6LY6FzsVW8TQ34Uxu6f2hs06v1vaWguMEROr4VsGf=w800-h387-no?authuser=0
Komora silnika posprzątana, wiązka silnika ułożona na swoim miejscu.
AMWts8BbUiXQwomMiBLsUEYIcW07kzCy34kuRuEa2ibiANW8ot7Vj7E1ilEOF4Zm4QdkRaBe8zEU4-mQBZLJdnHJ8oz3aFUgoPYCw9Q7q3GYj2_HzOKu5beqTqNdEuytcjIELFmhoeHGy_OjHbwT4pIs_9Rp=w438-h903-no?authuser=0
Jest też decyzja co do wnętrza. Sufit idzie w czarną alcantare (materiały już kupione czekają na cieplejsze dni). Fotele manualne z e92 w pół skórze z pompowanymi boczkami i grzaniem.
Foty z przymiarki:
AMWts8BPoINYE1dHGuZJzQDoy6u6S6CVRzM9O4Asa35CvTCNntnZwOX9UWrqaOY7_aM3vxgqCNQE3VnomLh7UVXvYx5LEiFDFIhqJLBt8VQoCfcWYgru1Fm15VztkraVE1fdt3dfYsc_VLjFFXFaYH7pEBAh=w438-h903-no?authuser=0
AMWts8CrfEyHPchw4qRgYw6FmC9x2Gk7J5CzLFZ5lwRoRLy-qttwVDUy6TbXTvOJjqpMtD94JD1mmRJ55X8FA5KQWY9FI7lwbZIKRazvq0TaoOARrFMw0Y0vLLlt-ipEbojOgWu57optdFUjGl4YeH4FIGh8=w800-h387-no?authuser=0
Kolejny etap to spięcie finalnie tylnego układu hamulcowego :D
