BMW e90 335xi WBAPL51030A741509
Siema, co sądzicie o tym e90? Czy możecie mi podpowiedzieć na co zwrócić uwagę przy N55? Bardzo podoba mi się ten samochód, nie chciałbym tylko popłynąć z drogimi naprawami. Czy ktoś ma jakieś doświadczenia na ten temat? :) Może ktoś już oglądał ten samochód?
http://allegro.pl/bmw-e90-335-i-xi-m-performance-pakiet-lemans-blue-i6637502727.html
IN: WBAPL51030A741509
Type code: PL51
Model: 335XI (EUR)
E-F-R series: E90 LCI (LifeCycleImpulse)
Series: 3
Type: LIM
Steering: LL
Doors: 4
Engine: N55
Displacement: 3.00
Power: 225 (306 hp)
Drive: ALLR
Transmission: MECH
Paint code: 381 - LE-MANS-BLAU METALLIC
Upholstery code: LCCX - LEDER DAKOTA/OYS
Prod.date: 2010-03-18
S1CA SELECTION COP RELEVANT VEHICLES
S1CB ACEA / CO2 scope
S1CD Brake Energy Regeneration
S2MF BMW alloy wheel, M spider spoke 193
S2PA Lockable wheel bolt
S3AP Windscreen with grey wedge
S4AE Armrest front, retractable
S4MG Int. mouldings aluminium glacier-silver
S5DC Rear-seat headrests, folding
S7NH BMW Service inclusive
S8AK Betriebsanleitung/Serviceheft slowakisch
S8SP Control unit COP
S203 4-wheel drive
S216 HYDRO STEERING-SERVOTRONIC
S230 Extra package, EU-speciifc
S249 Multifunction f steering wheel
S258 Tyres with runflat properties
S302 Alarm system
S319 Integrated universal remote control
S320 Deleted, model lettering
S321 Exterior parts in vehicle colour
P337 M Sports package
S423 Floor mats, velours
S428 Warning triangle and first aid kit
S430 Interior/outside mirror with auto dip
S431 Interior rear-view mirror with auto dip
S441 Smoker package
S459 Seat adjustment, electric, with memory
S464 Ski bag
S465 Through-loading system
S481 Sports seat
S493 Storage compartment package
S494 Seat heating driver/passenger
S497 Centre armrest, rear
S502 Headlight cleaning system
S507 Park Distance Control (PDC), rear
S520 Fog lights
S521 Rain sensor
S522 Xenon Light
S524 Adaptive Headlights
S534 Automatic air conditioning
S544 Cruise control with brake function
S548 Kilometre speedo
S563 Light package
S609 Navigation system, Professional
S672 CD changer for 6 CDs
S698 Area-Code 2 for DVD
S710 M leather steering wheel
S715 M Aerodynamics package
S752 Individual audio system
S760 High gloss shadow line
S775 Headlining anthracite
S818 Battery master switch
S851 Language version German
S863 Dealer List Europe
S877 Omission of non-combined operation
Jak bierzesz 335xi to raczej tanio nie będzie, spalanie średnio ze 14l. Wykup sobie historie u DRAY + zrób przegląd przedzakupowy porządny u kogoś kto sprawdzi ci kondycje turbin, pomp itd. a nie tylko przeleci miernikiem. Wysoko stoi i wygląda przez to jak koza na tym zawieszeniu, mnie by drażniło to osobiście i bym coś z tym robił po zakupie a to dodatkowe koszta. Poza tym jasny środek i manual nie w moim guście ale co kto woli, takich 335 na PL rynku świeżych praktycznie nie ma więc jak ci sie podoba to jedź sprawdzać
dzięki za odpowiedzi. Sprzedawca twierdzi, że tylko te drzwi były zrobione, ma podobno poszukać gdzieś zdjęć uszkodzeń, na razie czekam :) Sprężyny podobno są orginalne, czy mimo to wg was za wysoko siedzi?
Vaporr - akurat spalaniem się nie martwię, robię takie przebiegi, że nie ma to dla mnie żadnego znaczenia, akurator chodzi mi o serwisowanie. 335 oprócz droższe go w utrzymaniu silnika ma też droższe inne części?
Mole - możesz wyjaśnić o co chodzi z nadkolami? Uszczelki pod maską - chodzi o to, że powinny być, a nie ma bo wygląda jakby coś było robione :)? Szyby się odpryskują i się je wymienia, i to bym się akurat nie martwił.
Nie powinienem się czepiać, ale jak widzę opis , że najlepsze auto w Polsce to zastanawiam się dlaczego takie auto ma letnie opony z tyłu i zimowe z przodu...
Ta komora silnika też powinna być umyta bo teraz wygląda jakby miesiąc auto stało w lakierni w dziale szlifowania podkładu. Silnik może być brudny, ale komora powinna być czysta.
sprawdź luzy na wastegatach, to wazne przy 335i. Niech ktoś ci sprawdzi turbiny czy nie są do roboty bo to koszt +- 8000 jak coś się z nimi sypie, pompa, wtryski, skrzynia, zawieszenie, błędy na kompie. Prześwietl porządnie auto, przebieg ma nieduży 139tys ale z tego co wiem przy +-160-180tys zaczynają się problemy z tym co pisałem wyżej a wtedy koszta mogą iść w grubo ponad10tys. Nie mówie że tu tak musi być ale niech ci przepatrzy ktoś ogarnięty przed zakupem to auto a nie ktoś kto odhaczy "ptaszki" na liście bo takie sprawdzanie to o du..pe rozbić
Dzięki, planowałem po prostu podjechać do BMW w Lublinie (http://www.bmw-bestauto.pl/). Tam mi pewnie tego nie sprawdzą jak należy, ktoś zna może dobry warsztat w tamtych okolicach?
Co do komory silnika - chyba bym się tak tego nie czepiał, po co myć komorę silnika jeśli nie myje się samego silnika? Opony mnie faktycznie zastanawiają, nie pytałem o to właściciela co to za dziwy, chociaż od razu zauważyłem, że są różne a to dla xdrive nie za dobrze...
n55 ma jedną turbinę, używana za mniej niż połowę tego
Miałem na myśli oczywiście twin scroll turbo ale jak ktoś się czepi to zawsze znajdzie powód. Pewnie że możesz kupić używaną za mniej niż polowe tego a potem sie okaże że jest do du_py i kupować następną. Wiem jedno że koszta serwisu 335i są większe niż 335d a bierze się to głównie z tego że w 335i masz temperature pracy 115-130stopni a w 335d 90stopni i przez wysoką temp. elementy się szybciej zużywają ,to logiczne. Dlatego jak już brać 335i to lepiej sobie zostaw ze 20-30tys luźnej kasy na ewentualny serwis bo znam takich co szybko się pozbywali jej po zakupie bo ich nie było stać na utrzymanie ( srednie spalanie 13-14l jest tu akurat najmniejszym problemem)
To znaczy, że silnik i jego podzespoły nie są przystosowane do pracy w wyższych temperaturach? A w dieslu, skoro jest cięższy, to szybciej zużywają się hamulce, zawieszenie, napęd?
W 335d masz 2 turbiny - koszt obu jest większy niż w jednej w n55 i sporo większy nich obu w n54, wtryski w dieslu są ponad 2 razy droższe niż w benzynie (ponad 1000 zł różnicy na jednym wtrysku). Ile trzeba mieć zapasu na diesla?
Nie twierdzę, że utrzymanie 335i jest jakieś tanie, ale też nie ma co przesadzać.
Miałeś na myśli DWIE turbiny , które były w N54. Spokojnie przyznać się do błędu to żaden wstyd.
Hmm, z tego co piszecie wynika, że serwisowanie tego auta idzie w dziesiątki tysięcy co roku. Serio? 6 letnie auto z 140k przebiegu?
Wszystko zależy jak kupisz i ....jakim jesteś użytkownikiem.
Jeśli masz dwie lewe ręce, nie masz czasu i w dodatku pecha to mechanicy będą Cię kroić na wszystkim. Jeśli lubisz auta, znasz się na nich, potrafisz rozpoznać usterkę i przeciwstawić czarnowidztwu mechaników to może z autem nie być żadnych problemów.
A co do turbiny....5 mln diesli w Polsce gdzie każdy ma turbinę. Czyli lekko licząc rynek w samej regeneracji wart 7,5 mld ! rocznie.... Jakoś nie widzę na każdym rogu zakładów regenerujących.
Mocne silniki, to koszty utrzymania odpowiednio wysokie.
Niedługo przekroczę 200 tys w 330d, kupiona prawie nowa od dealera.
Wtedy zrobię podsumowanie kosztów i usterek.
Przyjmij koszt utrzymania na poziomie 10 -12 tys złotych (przeglądy,naprawy,ubezpieczenia,opony) przy przebiegu 20 -25 tys rocznie + oczywiście koszt paliwa.
Niedługo przekroczę 200 tys w 330d, kupiona prawie nowa dealera.
Dokładnie , mam 335i n54 i tyle trzeba liczyć .
Hmm, no to jednak nie ma tak źle :) Rocznie robię ok 10-15k km, ubezpieczenie liczę ok 3-4k, opony ok 3k (przy czym lubię sobie pojeździć, ale nie muszę non stop jeździć bokiem, czasami dziadkowa jazda jest relaksująca :D, więc chyba częściej niż co 30-40k km, jeżdżąc jak przeciętny użytkownik dróg, raczej nie będę ich potrzebował zmieniać?), więc nawet licząc 5-10k na serwis i naprawy to jednak nie jest jakaś magiczna kwota. Pytam o to wszystko, bo nie miałem wcześniej BMW i szukam już od sierpnia, nie celowałem w 335i, ale ta e90 wygląda ładnie, więc mnie zaciekawiło czy nie popłynę z kosztami. Myślę nawet, że jak na moje potrzeby, to ten samochód trochę ma za dużo mocy :D, no ale nie mogę znaleźć żadnego 325-330 godnego uwagi już od dłuższego czasu.
czy taka 325/330i będzie miała dużo niższe koszty eksploatacji? Opony te same, ubezpieczenie pewnie tańsze, ale to najwyżej kilka stówek. Zawieszenie, hamulce, filtry, oleje, itp.- nie chce mi się szukać po cennikach, ale jak nie będą takie same, to na pewno nie dużo tańsze. No jest jeszcze to turbo, ale to też można ogarnąć w normalnych pieniądzach. Ok, będzie taniej, ale czy tak dużo, zwłaszcza przy niskich przebiegach? Ważne żeby sprawdzić przed zakupem, wiele usterek wyłapać, bo jak się kupi ulepa to niezależnie od silnika będzie trzeba ładować kasę. Ja bym nie odrzucał 335i, do mocy się przyzwyczaisz i jeszcze będziesz chipował ;)
Mając taki budżet nie możesz od 6miesięcy kupić zdrowej 325i/330i ? To już nawet mnie to dziwi :mrgreen: Jedź z kimś ogarniętym bo już na samych fotkach widać parę irytujących minusów... na żywo jest przeważnie gorzej a nie lepiej. Pierwsze co zrób to dokręć korki mocowania chłodnicy :mrgreen:
Haha, ok, dzięki wszystkim za odpowiedzi, każdy dorzucił swoje 5gr i wygląda na to, że na samych zdjęciach jest już kilka rzeczy, które wy widzicie a ja nie, bo nie wiem na co zwracać uwagę :) Ciekawe ile z tego co piszecie to prawda, haha :) taki żarcik :)
Coraz mniej jestem przekonany do tego samochodu i mam trochę za daleko do niego, żeby jechać na taką wycieczkę rozpoznawczą, skoro już jest kilka argumentów przeciw.
Co do 325/330 - mój budżet jest mniejszy, po prostu dla naprawdę fajnego samochodu mógłbym wygospodarować trochę więcej kasy. W tym momencie (i od dłuższego czasu) nie ma na allegro nic co by mi odpowiadało, korzystam też z pomocy firmy, która szuka mi na konkretne zamówienie auta na zachodzie i też nic ciekawego (a raczej takiego jak sobie wymarzyłem) nie ma :/
