Przejrzałem już chyba wszystkie tematy z tym związane i dalej mam problem z podłączeniem się do samochodu
Z czym pracuję:
Interfejs:
http://allegro.pl/bmw-usb-1996-2006-inpa-pl-dis-e46-e90-e39-e60-e61-i2711881197.html
Inpa:
Próbowałem zarówno na 9.0.7 jak i 10.0.4
Konfiguracja portu:
COM 2
Odbiór: 1024
Transmisja: 1024
Opóźnienie:1
Przy instalacji inpy ustawiałem zarówno na ADS jak i OBD i nic.
Pliki EDIABAS.ini i OBD.ini
;EDIABAS 6.4.3 Configuration
[Configuration]
; EcuPath
; Description : ECU file path
; Default = .
EcuPath = C:\EDIABAS\ECU
; SimulationPath
; Description : Simulation file path
; Default = .
SimulationPath = C:\EDIABAS\SIM
; TracePath
; Description : Trace file path
; Default = .
TracePath = C:\EDIABAS\TRACE
; CodeMapping
; Description : Character mapping file path
; Default = .
;CodeMapping = C:\EDIABAS\BIN\ansi2oem.tab
; TraceSize
; Description : Maximum size of each trace file [KB]
; Value : 0..32767
; Default = 1024
;TraceSize = 1024
; ApiTrace
; Description : Enable/Disable API/User trace
; Value : 0 = Trace disabled
; 1 = User trace
; 2 = User trace + time stamp
; 3 = User trace + time stamp + process id (Win32)
; 4 = Function trace
; 5 = Function trace + time stamp
; 6 = Function trace + time stamp + timing
; 7 = Function trace + time stamp + timing + process id (Win32)
; Default = 0
ApiTrace = 0
; IfhTrace
; Description : Enable/Disable IFH trace
; 1 = Trace enabled
; 2 = Trace enabled
; 3 = Trace enabled
; Default = 0
IfhTrace = 0
; SystemTraceSys
; Description : Enable/Disable system trace (runtime system)
; Trace levels 1..7
; Default = 0
SystemTraceSys = 0
; SystemTraceBip
; Description : Enable/Disable BIP trace (runtime system)
; Trace levels 1..7
; Default = 0
SystemTraceBip = 0
; SystemTraceIfh
; Description : Enable/Disable IFH system trace
; Trace levels 1..7
; Default = 0
SystemTraceIfh = 0
; SystemTraceNet
; Description : Enable/Disable network trace
; Trace levels 1..7
; Default = 0
SystemTraceNet = 0
; BipDebugLevel
; Description : BIP debug level of ECU files
; Value : 0..32767
; Default = 0
BipDebugLevel = 0
; UbattHandling
; Description : Ubatt ON/OFF handling
; Value : 0 = Ubatt ON/OFF: No EDIABAS error
; 1 = Ubatt ON/OFF: EDIABAS error
; Default = 1
UbattHandling = 1
; IgnitionHandling
; Description : Ignition ON/OFF handling
; Value : 0 = Ignition ON/OFF: No EDIABAS error
; 1 = Ignition ON/OFF: EDIABAS error
; Default = 1
IgnitionHandling = 1
; TaskPriority
; Description : EDIABAS process/thread priority (only Win32/16)
; Value : 0 = Optimal EDIABAS performance = 8
; 1 = Minimal EDIABAS performance
; 10 = Maximal EDIABAS performance
; Default = 0
TaskPriority = 0
; LoadWin32
; Description : Map EDIABAS Win16 calls to EDIABAS Win32
; Value : 0 = Win16/32 Mapping disabled (Win16-->Win16)
; 1 = Win16/32 Mapping enabled (Win16-->Win32)
; Default = 0 for Windows 9x/Me
; Default = 1 for Windows NT4/2000/XP
LoadWin32 = 1
; SystemResults
; Description : Enable/Disable system results (ubatt/ignition/jobstatus)
; Value : 0 = Disable system results
; 1 = Enable system results
; Default = 1
SystemResults = 1
; RetryComm
; Description : Repeat failed communication automatically (1x)
; Value : 0 = Retry disabled
; 1 = Retry enabled (1x)
; Default = 1
RetryComm = 1
; Simulation
; Description : Enable/Disable ECU simulation
; Value : 0 = Simulation disabled
; 1 = Simulation enabled
; Default = 0
Simulation = 0
; Interface
; Description : Connected diagnosis interface
; Default = EDIC
Interface = STD:OBD
; Additional information (in German) :
; Bitte beachten: Der HW-Treiber fuer das Interface muss installiert sein!
; Interface = STD:OBD
; Beschreibung : Serieller Pegelwandler (Nachfolger von ADS / Anschluss an OBD-Dose)
; Installation : \EDIABAS\HARDWARE\OBD\ODBSETUP (nur noetig fuer WIN NT4, WIN 2000, WIN XP)
; INI-Datei : OBD.ini nur benutzt wenn im Windows-Verzeichnis
; Unterstuetzung : WIN3.xx : Nein
; WIN95,98 16-Bit : Ja
; WIN95,98 32-Bit : Ja
; WIN NT 4.0 : Ja
; WIN XP : Ja
; Interface = STD:FUNK
; Beschreibung : Funk-Diagnose Interface MDA von Fa. Siemens
; Installation : keine
; INI-Datei : FUNK.INI
; Unterstuetzung : WIN95,98 16-Bit : Ja
; WIN NT 4.0 : Ja
; WIN XP : Ja
; Interface = ADS
; Beschreibung : Serieller Pegelwandler (Anschluss an Diagnose-Dose)
; Installation : \EDIABAS\HARDWARE\ADS\ADS32\ADSSETUP (nur fuer WinNT4 noetig)
; INI-Datei : keine
; WIN95,98 32-Bit : Nein
; WIN NT 4.0 : Ja
; WIN XP : Ja
; Interface = KBUS
; Beschreibung : Serieller Pegelwandler (Anschluss direkt an K-Bus oder I-Bus)
; INI-Datei : keine
; WIN NT 4.0 : Ja
; WIN XP : Ja
; Interface = EDIC
; Beschreibung : Serielles , PCMCIA , PC-Card Interface von Fa. Softing
; Installation : \EDIABAS\HARDWARE\EDIC\SETUP.EXE
; INI-Datei : EDICFW.INI, EDICHW.INI
; WIN NT 4.0 : Ja
; WIN XP : Ja
; Interface = EDICC
; Beschreibung : EDIC-Card C oder EDIC-Card 2 CAN-Interface von Fa. Softing
; INI-Datei : XEDICC.INI
; WIN NT 4.0 : Ja
; WIN XP : Ja
; Interface = STD:CAN
; Beschreibung : PCMCIA CAN-Interface CanCardX von Fa. Vector
; Installation : keine (ausser Installation der CAN-Karte)
; INI-Datei : CANRTTP.INI
; Unterstuetzung : WIN95,98 16-Bit : ?
; WIN95,98 32-Bit : ?
; WIN NT 4.0 : Ja
; WIN XP : ?
; Ansprechpartner: Hr. Jusko
; Telefon : +49-(0)89/382-35891 (Hotline)
; email : [email protected] (Hotline)
; Interface = STD:ADS4MOST
; Beschreibung : Most-Interfaces von Fa. Oasis
; Installation : keine (ausser Installation der Oasis-Karte)
; INI-Datei : ADS4MOST.INI
; WIN NT 4.0 : Ja
; WIN XP : Ja
; Ansprechpart.: Hr. Rowedder
; Telefon : 089 / 382-29159
; Interface = REMOTE
; Beschreibung : Anbindung eines EDIABAS-Interfaces über TCP/IP
; Installation : Anpassung der Einträge in [TCP] auf beiden Seiten (ins.: RemoteHost, Port)
; INI-Datei : keine
; Unterstuetzung : WIN95,98 16-Bit : Nein
; WIN NT 4.0, XP : Ja
; WIN XP : Ja
; Sonderfall : Interface OPPS
; Interface = REMOTE:name
; INI-Datei : REMOTE.INI (insbesondere für Parallelbetrieb notwendig)
; In REMOTE.INI stehen unter [name] spezif. Einstellungen(z.B.: RemoteHost, Port)
; WIN XP : Ja
; NetworkProtocol
; Description : Network protocol
; Default =
NetworkProtocol = TCP
;TCP/IP Configuration
[TCP]
; RemoteHost
; Description : server address/name
; Default =
RemoteHost = 192.168.68.1
; Port
; Description : IP communication port
; Value : 1000 < port < 30000
; Default =
Port = 6801
;TimeoutConnect
; Description : Timeout for establishing the connection
; Default = 5000
TimeoutConnect = 2000
;TimeoutReceive
; Description : Timeout for receiving a message
; Default = 5000
TimeoutReceive = 2000
;TimeoutFunction
; Description : Timeout for a long function
; Default = 59000
TimeoutFunction = 10000
;DisconnectOnApiEnd
; Description : Enable/Disable Disconnection with function call ApiEnd
; Value : 0 = Disconnection disabled
; 1 = Disconnection enabled
; Default = 0
;DisconnectOnApiEnd = 1
;InitCmd
; Description : Initialization command (normally for OPPS)
; Default =
;InitCmd0 = FE,04,00,03,01
;InitCmd1 = FD,05,00,03,01
; End Of File EDIABAS.ini
[OBD]
Port=Com1
TRACELEVEL = 0x00000000
HARDWARE=OBD
RETRY=ON
MODE=NORMAL
;OBD-Stecker OBD
;OBD-Stecker am USB->Seriell-Adapter USB
;alte ADS-Hardware ADS
;Tracelevel=0xFFFFFFFF
;Tracelevel=0xF0000000
;Tracelevel=0x0000FFFF
; Bit 0 = Funktionsaufruf
; Bit 1 = io Ergebnis
; Bit 2 = nio Ergebnis
; Bit 3 = Detailinfos
; Nibble 0 = readchar_wait
; Nibble 1 = main
; Nibble 2 = cmd
; Nibble 3 = obd
; Nibble 4 = send_and_receive_...
; Nibble 5 = read_telegram_...
; Nibble 6 = send_telegram
; Nibble 7 = SendData
;[uNIT_x] x = A, B, ...,Y, Z, 0, 1, .., 8, 9
;Port = Com1 COM1 .. COM9
;TRACELEVEL = 0x00000000 0x00000000 .. 0xFFFFFFFF
;RETRY = OFF OFF, ON
;MODE=NORMAL NORMAL, KBUS
;HARDWARE=OBD OBD, USB, ADS
[uNIT_A]
Port=Com1
Hardware=OBD
RETRY=ON
MODE=NORMAL
[uNIT_B]
Port=Com2
Hardware=OBD
[uNIT_C]
Port=Com3
Hardware=OBD
[uNIT_D]
Port=Com4
Hardware=OBD
[uNIT_E]
Port=Com5
Hardware=OBD
[uNIT_F]
Port=Com6
Hardware=OBD
[uNIT_G]
Port=Com7
Hardware=OBD
[uNIT_H]
Port=Com8
Hardware=OBD
[uNIT_I]
Port=Com9
Hardware=OBD
[uNIT_J]
Port=Com10
Hardware=OBD
[uNIT_K]
Port=Com11
Hardware=OBD
[uNIT_L]
Port=Com12
Hardware=OBD
[uNIT_M]
Port=Com13
Hardware=OBD
[uNIT_N]
Port=Com14
Hardware=OBD
[uNIT_O]
Port=Com15
Hardware=OBD
System XP + SP3
Interfejs zainstalował mi się w Kontrolerach uniwersalnej magistrali szeregowej jako USB Serial Converter tak ma być?
Nie mogę się połączyć, cały czas mam ignition i battery OFF, żadne testy nie chodzą.
Skończyły mi się pomysły i prosiłbym o pomoc.
jakie instalowałeś sterownika do kabelka od nich czyli te co ci podesłali z kabelkiem czy nowsze z netu , miałem ten sam problem po zainstalowaniu nowszych sterowników wszystko śmiga aż miło
Daj tak:
; RemoteHost
; Default =
RemoteHost = 192.168.68.30
; Port
; Default =
Port = 6801
a w obd.ini w zależnośći od Portu Com1 lub Com2
[OBD]
Port=Com1
Hardware=OBD
RETRY=ON
UBATT=OFF
[uNIT_A]
Port=Com2
Hardware=OBD
[uNIT_B]
Port=Com3
Hardware=OBD
[uNIT_C]
Port=Com4
Hardware=OBD
[uNIT_D]
Port=Com5
Hardware=OBD
[uNIT_E]
Port=Com6
Hardware=OBD
[uNIT_F]
Port=Com7
Hardware=OBD
[uNIT_G]
Port=Com8
Hardware=OBD
[uNIT_H]
Port=Com9
Hardware=OBD
[uNIT_I]
Port=Com10
Hardware=OBD
[uNIT_J]
Port=Com11
Hardware=OBD
[uNIT_K]
Port=Com12
Hardware=OBD
[uNIT_L]
Port=Com13
Hardware=OBD
[uNIT_M]
Port=Com14
Hardware=OBD
no proszę, a skąd miałęś taki info ? :mrgreen:
wwo_j
masz racje kolego podałeś mi namiar na stery , ale dostałem cała paczke od innego kolegi z forum wraz z inpą
Ja mam problem z połączeniem z autem jak mam uruchomiony program w tle do łączenia z telefonem.
Jak idę do auta wyłączam w menedżerze zadań niepotrzebne zadania uruchomione przez użytkownika i tu "twój login do kompa",
Po wyłączeniu powyższego programu Battery On i Ignition On, przed wyłączeniem 2x off.
Pozdrówka
dziś ci nie powiem, bo laptopa nie mam przy sobie. Jutro porównam pliki i dam znać
ediabas.ini
;EDIABAS 6.4.7 Configuration
[Configuration]
; EcuPath
;       Default     =   .
EcuPath          =C:\EDIABAS\ECU
; SimulationPath
;       Default     =   .
SimulationPath   =C:\EDIABAS\SIMULATION
; TracePath
;       Default     =   .
TracePath        =C:\EDIABAS\TRACE
; CodeMapping
;       Default     =   .
; TraceSize
;       Value       :   0..32767
;       Default     =   1024
TraceSize        = 32767
; ApiTrace
;                       1  = User trace
;       Default     =   0
ApiTrace         =0
; IfhTrace
;                       1  = User trace
;                       2  = User trace + interface
;                       3  = User trace + interface + time stamp
;       Default     =   0
IfhTrace         =0
; IfhnTrace
;       Description :   Enable/Disable IFH network trace (with XREMOTE)
;                       1  = User trace
;       Default     =   0
;IfhnTrace        = 0
; SystemTraceSys
;                       Trace levels 1..7
;       Default     =   0
SystemTraceSys   = 0
; SystemTraceBip
;                       Trace levels 1..7
;       Default     =   0
SystemTraceBip   = 0
; SystemTraceIfh
;                       Trace levels 1..7
;       Default     =   0
SystemTraceIfh   = 0
; SystemTraceNet
;                       Trace levels 1..7
;       Default     =   0
SystemTraceNet   = 0
; BipDebugLevel
;       Value       :   0..32767
;       Default     =   0
BipDebugLevel    = 0
; UbattHandling
;       Default     =   1
UbattHandling    = 0
; IgnitionHandling
;       Default     =   1
IgnitionHandling = 0
; ClampHandling
;       Description :   automatic check of clamps for Ubatt and Ignition
;       Value       :   0  = no automatic clamp check with send_and_receive
;                       1  = automatic clamp check with send_and_receive
;       Default     =   1
;ClampHandling    = 1
; TaskPriority
;       Default     =   0
TaskPriority     = 0
; LoadWin32
;LoadWin32        = 0
; SystemResults
;       Default     =   1
SystemResults    = 1
; RetryComm
;       Default     =   1
RetryComm        = 1
; Simulation
;       Default     =   0
Simulation       = 0
; Interface
;       Default     =   STD:OBD
Interface        =STD:OBD
; INI-Datei      : Suchreihenfolge analog zu EDIABAS.ini
;                  WIN NT 4.0       : Ja
;                  WIN XP           : Ja
;                  WIN NT 4.0       : Ja
;                  WIN XP           : Ja
; Interface      = ADS
; INI-Datei      : keine
;                  WIN NT 4.0       : Ja
;                  WIN XP           : Ja
; Interface      = KBUS
; INI-Datei      : keine
;                  WIN NT 4.0       : Ja
;                  WIN XP           : Ja
; Interface      = EDIC
;                  WIN NT 4.0       : Ja
;                  WIN XP           : Ja
; Interface      = EDICC
;                  WIN NT 4.0       : Ja
;                  WIN XP           : Ja
; Beschreibung   : PCMCIA CAN-Interface CanCardX/XL von Fa. Vector
; INI-Datei      : CAN32.INI
;                  WIN NT 4.0       : Ja
;                  WIN XP           : Ja
;                  WIN NT 4.0       : Ja
;                  WIN XP           : Ja
; INI-Datei      : keine
;                  WIN XP           : Ja
;                  WIN XP           : Ja
; NetworkProtocol
;       Default     =
[TCP]
; RemoteHost
;       Default     =
; Port
;       Default     =
Port                 = 6801
;TimeoutConnect
;       Default     =   5000
;TimeoutReceive
;       Default     =   5000
;TimeoutFunction
;       Default     =   59000
;DisconnectOnApiEnd
;       Default     =   0
;InitCmd<n>
;       Description :   Initialization command <n> (normally for OPPS)
;       Default     =
obd.ini
[OBD]
Port=Com1
Hardware=OBD
RETRY=ON
UBATT=OFF
; Nibble 1 = main
; Nibble 2 = cmd
; Nibble 3 = obd
[UNIT_A]
Port=Com2
Hardware=OBD
[UNIT_B]
Port=Com3
Hardware=OBD
[UNIT_C]
Port=Com4
Hardware=OBD
[UNIT_D]
Port=Com5
Hardware=OBD
[UNIT_E]
Port=Com6
Hardware=OBD
[UNIT_F]
Port=Com7
Hardware=OBD
[UNIT_G]
Port=Com8
Hardware=OBD
[UNIT_H]
Port=Com9
Hardware=OBD
[UNIT_I]
Port=Com10
Hardware=OBD
[UNIT_J]
Port=Com11
Hardware=OBD
[UNIT_K]
Port=Com12
Hardware=OBD
[UNIT_L]
Port=Com13
Hardware=OBD
[UNIT_M]
Port=Com14
Hardware=OBD
[UNIT_N]
Port=Com15
Hardware=OBD
[UNIT_O]
Port=Com16
Hardware=OBD
zobacz na tych, i daj znać
żeby zainstalować nowe ftdi musisz odinstalować stary ster. Jak niema opcji odinstalowania to spr.http://www.ftdichip.com/Support/Utilities.htm
CDM Uninstaller 1.4
Panie i Panowie. Mam ultimate evolt cable solution do naszych ultimate driving machine :).
Czyli, kto ma kabel od EVOLTA jest szczesciarzem - jak sie go dobrze skonfiguruje, to faktycznie wykrywa zaplon a nie tylko ma zwarte piny na stale!
Co nalezy zrobic (instrukcja dla Win Xp).
1) Po otrzymaniu kabla nie instalowac starych sterow od nich!
2*) Jesli sie je zainstalowalo to sciagamy http://www.ftdichip.com/Support/Utilities/CDMUninstaller_v1.4.zip i usuwamy je
3) Sciagamy sterowniki najnowsze ze strony producenta chipu http://www.ftdichip.com/Drivers/VCP.htm
4) Ustawiamy w ustawieniach emulatora COM, zeby byl COM1, Latency timer 1 etc (tak jak w kazdym manualy do inpy. np od nerwusa)
5) W EDIABAS/BIN szukamy OBD.ini i zmieniamy w pierwszej linijce (DLA COM=1) HARDWARE=USB zamiast OBD. Oprocz tego dopisujemy UBATT=OFF.
6) Plik zostaje w tym katalogu, ale kopiujemy go tez do katalogu Windows (bezposrednio)
7) Teraz kabel pokazuje zawsze BATT ON ale ma detekcje INGITION!
Mialem ten problem co wy i zrezygnowany zaczalem kombinowac. To co powyzej sprawilo, ze kabel dziala super!
Powodzenia! :cool2:
No widzisz, a mi pomoglo ;). Albo to, albo wgranie do katalogu windowsa dodatkowo pliku OBD.ini. Jak nie dalem hardware na USB (albo to przegranie OBD.ini?) to nie czytal mi stanu Ignition (sprawdze w wolnej chwili, ale to USB jako hardware nie przeszkadza). Teraz mam w pelni aktywne czytanie. Przed przekreceniem zaplanu tylko BATT ON a po IGNITION ON :8) .
  • 2 miesiące temu...
Witam :)
Panowie powiedzcie mi czy kontrolka battery powinna świecic sie po podpięciu samego kabla czy dopiero gdy kabel jest podłączony do samochodu? mam kabel evolta zrobilem wszystko wg powizszej instrukcji i nie dziala :(
Witam :)
Panowie powiedzcie mi czy kontrolka battery powinna świecić sie po podpięciu samego kabla czy dopiero gdy kabel jest podłączony do samochodu? mam kabel evolta zrobilem wszystko wg powizszej instrukcji i nie dziala :(
Jak masz porządny kabel to bateria świeci się jak podepniesz dopiero pod auto, a zapłon jak dasz zapłon.
Ale sprzedają fejsy które na stałe maja zapłon i baterie lub sama baterie przez modyfikacje obd.ini.
We wszystkich przypadkach jak fejs jest ok powinno działać.
post do usuniecia Edytowane przez wajser
Witam, ludzie pomóżcie, bo już jestem na skraju wyczerpania nerwowego :mad2: A więc opiszę o co chodzi. Mam zainstalowaną inpę i disa gotowego od trandolfa na vmware i odpalam inpe włącza się normalnie ale jest battery off i ingnition off nawet po podłączeniu do samochodu ;/ Więc postanowiłem ,że zainstaluje sam od nowa wszystko, zainstalowałem inpe (oczywiście na vwmare, na czystym xp), najnowsze stery do kabla (kabel obd od e-volta), skonfigurowałem z com1, zmienna środowiskowa dodana i co? nadal to samo battery off i ingnition off :mad2:
Dodam jeszcze, że próbowałem wyżej wymienionych wskazówek i nic... Ma ktoś jakiś pomysł na to? Bo jeszcze trochę i nie wytrzymam, laptop będzie latał po podwórku.. :evil:
Niżej wklejam pliki EDIABAS.ini i OBD.ini
[Configuration]
; EcuPath
; Default = .
; SimulationPath
; Default = .
; TracePath
; Default = .
; CodeMapping
; Default = .
; TraceSize
; Value : 0..32767
; Default = 1024
TraceSize = 32767
; ApiTrace
; 1 = User trace
; Default = 0
ApiTrace =0
; IfhTrace
; 1 = User trace
; Default = 0
IfhTrace =0
; IfhnTrace
; 1 = User trace
; Default = 0
;IfhnTrace = 0
; SystemTraceSys
; Trace levels 1..7
; Default = 0
SystemTraceSys = 0
; SystemTraceBip
; Trace levels 1..7
; Default = 0
SystemTraceBip = 0
; SystemTraceIfh
; Trace levels 1..7
; Default = 0
SystemTraceIfh = 0
; SystemTraceNet
; Trace levels 1..7
; Default = 0
SystemTraceNet = 0
; BipDebugLevel
; Value : 0..32767
; Default = 0
BipDebugLevel = 0
; UbattHandling
; Default = 1
UbattHandling = 0
; IgnitionHandling
; Default = 1
; ClampHandling
; Default = 1
;ClampHandling = 1
; TaskPriority
; Default = 0
TaskPriority = 0
; LoadWin32
;LoadWin32 = 0
; SystemResults
; Default = 1
SystemResults = 1
; RetryComm
; Default = 1
RetryComm = 1
; Simulation
; Default = 0
Simulation = 0
; Interface
; Default = STD:OBD
Interface =STD:OBD
; WIN NT 4.0 : Ja
; WIN XP : Ja
; WIN NT 4.0 : Ja
; WIN XP : Ja
; Interface = ADS
; INI-Datei : keine
; WIN NT 4.0 : Ja
; WIN XP : Ja
; Interface = KBUS
; INI-Datei : keine
; WIN NT 4.0 : Ja
; WIN XP : Ja
; Interface = EDIC
; WIN NT 4.0 : Ja
; WIN XP : Ja
; Interface = EDICC
; WIN NT 4.0 : Ja
; WIN XP : Ja
; WIN NT 4.0 : Ja
; WIN XP : Ja
; WIN NT 4.0 : Ja
; WIN XP : Ja
; INI-Datei : keine
; WIN XP : Ja
; WIN XP : Ja
; NetworkProtocol
; Default =
[TCP]
; RemoteHost
; Default =
; Port
; Default =
Port = 6801
;TimeoutConnect
; Default = 5000
;TimeoutReceive
; Default = 5000
;TimeoutFunction
; Default = 59000
;DisconnectOnApiEnd
; Default = 0
;InitCmd
; Default =
[OBD]
Port=Com1
Hardware=USB
RETRY=ON
UBATT=OFF
; Nibble 1 = main
; Nibble 2 = cmd
; Nibble 3 = obd
[uNIT_A]
Port=Com2
Hardware=OBD
[uNIT_B]
Port=Com3
Hardware=OBD
[uNIT_C]
Port=Com4
Hardware=OBD
[uNIT_D]
Port=Com5
Hardware=OBD
[uNIT_E]
Port=Com6
Hardware=OBD
[uNIT_F]
Port=Com7
Hardware=OBD
[uNIT_G]
Port=Com8
Hardware=OBD
[uNIT_H]
Port=Com9
Hardware=OBD
[uNIT_I]
Port=Com10
Hardware=OBD
[uNIT_J]
Port=Com11
Hardware=OBD
[uNIT_K]
Port=Com12
Hardware=OBD
[uNIT_L]
Port=Com13
Hardware=OBD
[uNIT_M]
Port=Com14
Hardware=OBD
[uNIT_N]
Port=Com15
Hardware=OBD
[uNIT_O]
Port=Com16
Hardware=OBD
