Zafi
  • Wygrane w rankingu
    2
Treść opublikowana przez Zafi
  1. witam tu jest material szkoleniowy BMW E60 / Pdf : https://www.google.de/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&cad=rja&uact=8&ved=0ahUKEwiZyPfNxfTMAhVBjiwKHRGnBD0QFggkMAE&url=http%3A%2F%2Fwww.m5board.com%2Fvbulletin%2Fattachments%2Fe60-m5-e61-m5-touring-discussion%2F228057d1366041852-m5-m6-s85-recall-tech-service-bulletin-service-information-bulletin-technical-docs-thread-one-stop-shop-08_e60-climate-control.pdf&usg=AFQjCNGR5Yml-apen5iWCMyF-_uQoH1AUQ&bvm=bv.122852650,d.bGg na stronie Nr. 13 - Components Located on IHKA Housing http://fs5.directupload.net/images/160525/29c69k9m.png http://fs5.directupload.net/images/160525/m6eh246p.png
  2. witam 67 Headlight Washer System > 1 RA Overview Of Windscreen Wiper And Washer System http://workshop-manuals.com/bmw/3_series_e90/318d_m47t2_sal/2_repair_instructions/61__general_electrical_system/67__headlight_washer_system/1_ra__overview_of_windscreen_wiper_and_washer_system/ 67 Headlight Washer System > 3 RA Removing And Installing _ Replacing Left Or Right High-pressure Nozzle Of Headli > Page 2417 http://workshop-manuals.com/bmw/3_series_e90/330i_n53_sal/2_repair_instructions/61__general_electrical_system/67__headlight_washer_system/3_ra__removing_and_installing___replacing_left_or_right_high-pressure_nozzle_of_headli/page_2417/ http://fs5.directupload.net/images/160524/8uny27vn.png
  3. witam The fuel tank capacity is 67 liters, including 8 liters of reserve fuel. http://fs5.directupload.net/images/160523/3utpx32f.png
  4. BMW X3 (2017) Mehr Technik, mehr Power BMW X3 (2017) więcej technologii, więcej mocy Der SUV-Markt boomt, und die Konkurrenz wird härter. 2016 erscheint der neue Audi Q5, BMW muss mit dem X3 nachziehen. Er soll ein Jahr später mit modernster Technik und starken Motoren punkten. Na rynku SUV jest boom, a konkurencja jest coraz mocniejsza (twarda). W 2016 pojawi się nowe Audi Q5, BMW musi z X3 dorównać . On musi rok później z najnowocześniejszyą technologią i mocnymi silnikami zbierać punkty. Der X3 steht schon im eigenen Haus mächtig unter Druck. Von unten kratzt der erstaunlich erwachsene X1, von oben spielt jetzt auch der neue X5 die Vierzylinder-Trumpfkarte. Doch der neue X3 (Entwicklungskürzel G01) schöpft aus dem Vollen. Das liegt an der neuen Plattform CLAR ("Cluster Architecture"), die zuvor schon vom neuen BMW 5er genutzt wird. Das verhilft zu 100 Kilogramm weniger Gewicht und mehr Innenraumlänge. Eine neu konstruierte Sitzanlage sorgt außerdem für höhere Variabilität und besseren Komfort. X3 jest już we „wlasnym domu“ pod ogromną presją. Od dołu ociera niesamowicie dorosły X1, z „góry„ ,zagrywa nowy X5, czterocylindrowym - atutem . Ale nowy X3 (kryptonim rozwojowy G01) wywodzi się z nieograniczonych zasobów. Wynika to z nowej platformy CLAR ( "Cluster Architecture"), która jest wcześniej używana przez BMW w serii 5. Przyczynia się to do zmniejszenia masy o 100 kg i większej długości wnętrza. Nowo zaprojektowane fotele ( siedzenia ) zapewniają również większą wszechstronnosc i lepszy komfort. Ein Dreizylinder ist für den neuen X3 nicht vorgesehen. Als gesetzt gelten die neuen Zweiliter-Diesel und die mit den Vierzylindern verwandten neuen Dreiliter-Sechszylinder. Bei allen Motoren steigt die Leistung gegenüber den Vorgängern um mindestens 15 PS. Um Sprit zu sparen, wird es künftig mehr zweiradgetriebene Varianten geben. Neu im Programm ist der ab 2017 verfügbare X3 xDrive M40i mit dem 360 PS starken Dreiliter-Biturbo-Reihensechszylinder. Ein Jahr später erwarten wir den X3 M mit 431 PS, dessen Motor erst 2014 im M3 und M4 Premiere feierte. Trzycylindowy ( silnik) nie jest przewidziany dla nowego X3. Napewno, nowe dwulitrowe diesle i spokrewnione z cztero- cylindrowymi nowe trzy- litrowe sześciocylindrowe silniki . We wszystkich silnikach wzrasta moc w porównaniu ze swymi poprzednikami co najmniej 15 KM. Aby zaoszczędzić paliwo, będzie wkrótce więcej wersji napędzanych na dwa koła. Nowością w programie jest dostępna od 2017 X3 xDrive M40i z 360 KM trzy- litrowym twin-turbo sześciocylindrowym (rzedowym) . Rok później oczekujemy X3 M z 431 KM, silnik ktorego premiera byla w 2014 roku w M3 i M4 . BMW X3 M in Planung Die annähernd gleiche PS-Palette ist für den Nachfolger des X4 (G02) vorgesehen, der angeblich schon im Juli 2018 auf den Markt kommt, was die Laufzeit des aktuellen Autos auf ungewöhnlich knappe vier Jahre verkürzen würde. Im Gegensatz zum X4 soll der nächste X3 ab Ende 2019 auch als Plug-in-Hybrid vom Band rollen. Mit 220 PS und 385 Nm dürfte der Doppelherz-X3 die Grenze von 50 g CO2/km locker unterschreiten. Vollgetankt und mit vollen Akkus darf mit einer Reichweite von 550 km gerechnet werden. Geladen werden die Lithium-Ionen-Akkus entweder an der Steckdose oder später induktiv und damit kabellos. BMW X3 M w planowaniu Prawdopodobnie podobny zakres KM przewidziany jest w następcy X4 (G02), który rzekomo wchochodzi już w lipcu 2018 roku na rynek, co skróciłoby czas trwania cyklu producyjnego obecnych samochodów na niezwykle krotkie cztery lata. W przeciwieństwie do X4, następny X3 będzie toczyc sie od końca 2019 roku z taśmy rowniez jako plug-in hybrid. Z 220 KM i 385 Nm z podwójnego serca X3 łatwo osiagnie granice poniżej 50 g CO2 / km. W pełni zatankowany i z naładowanymi akumulatorami można oczekiwać zakresu 550 km. Akumulatory litowo-jonowe bedą ladowane albo przez gniazdka elektryczne lub później indukcyjnie, a więc bezprzewodowo. Gestensteuerung und Einparken auf Knopfdruck Auch im neuen X3 bringt BMW einen Mix aus Touchpad-Controller, mittigem Touchscreen, zweitem Monitor im Sichtfeld des Fahrers, optionalem Head-up-Display sowie erweiterter Sprach- und Gestensteuerung. Ebenfalls mit an Bord sind Einparken auf Knopfdruck, diverse Vorausschaufunktionen auf Navi- und Sensorbasis sowie das vernetzte Dynamiklicht. Sterowanie gestami i parking na „ przycisk“ Rowniez nowy X3 przynosi BMW mieszankę ze sterownika touchpada, centralnego ekranu dotykowego, drugiego monitorza przed kierowcą, opcjonalny HUD (Head-up-Display ) oraz wieksza kontrola głosem i gestami. Również na pokładzie są parkowanie na „przycisk“ , rozne funkcje dzialajace na podstawie nawigacji i bazie czujnikow oraz „polączone siecią“ „dynamiczne światła“. Anders als der X5 bleibt der kleine Bruder der einteiligen Heckklappe treu. Die Scheibe lässt sich separat öffnen, gegen Aufpreis öffnet die Klappe wie bisher elektrisch, auch auf eine Fußbewegung unterm Stoßfänger hin. Es bleibt zwar bei nur zwei Sitzreihen, aber dafür können die Fondsitze gegen Aufpreis in Höhe, Länge und Lehnenneigung verstellt werden. Das Abdeckrollo verschwindet bei Nichtgebrauch in einer Aussparung im Kofferraumboden. Das auf Wunsch eingebaute Panoramadach besitzt eine deutlich größere Öffnung, eine doppelte Entlüftungsstellung (vorn/hinten) und einen zweiten Windabweiser als Schutzmaßnahme gegen Staudruck. W przeciwieństwie do X5 mały brat pozostaje przy jednoczęściowej klapie tylnnej. Szyba może być otwierana oddzielnie, za dopłatą tylna pokrywa otwiera sie elektrycznie tak jak w poprzedniku, reaguje rowniez na ruch stopą pod zderzakiem tylnym. Pozostają dwa rzędy siedzeń, jednak tylne siedzenia można regulować : wysokość, długość oraz kąt oparcia za dodatkową opłatą. Pokrywa roller znika, gdy nie jest w użyciu w zagłębieniu w podłodze bagażnika. Wbudowany opcjonalny dach panoramiczny ma znacznie większy otwór, podwójne odpowietrzanie (przód / tył) i drugi deflektor jako ochroniacz przed nadmiernym cisnienieniem. Verbesserte Aerodynamik An der Verkehrsfläche des X3 ändert sich nach dem Modellwechsel kaum etwas. Radstand, Höhe und Breite legen geringfügig zu. In Verbindung mit Sechszylindermotoren sind 19-Zöller und größere Bremsen Serie, zusätzlich zur xLine wird wieder ein M-Sportpaket angeboten. Die Front steht aufgrund der neuen Fußgängerschutz-Bedingungen etwas aufrechter im Fahrtwind als bisher. Zu den auffälligsten Aerodynamik-Maßnahmen gehören die Entlüftung der vorderen Radhäuser, die ungewöhnlich hohe umlaufende hintere Abrisskante und der markante Dachspoiler. Die seitliche Sicke auf Höhe der Türgriffe ist künftig in einem Stück durchgezogen. Poprawiona aerodynamika W obrysach X3 zmienia sie niewiele. Rozstaw osi, wysokość i szerokość zwiększa sie nieznacznie . W połączeniu z sześciocylindrowymi silnikikami są 19-stki i większe hamulce seryjnie, dodatkowo xLINE sport Pakiet M zostanie ponownie zaoferowany. Przòd jest ze względu na nowe warunki ochrony pieszych bardziej pionowy do wiatru niż dotychczas. Wśród najbardziej zaskakujących środków aerodynamicznych są odpowietrzania przednich nadkoli, niezwykle wysoki obwod tylnego spoilera i uderzający spojler dachowy. Zgrubienie poprzeczne na poziomie klamek jest przeciągane w przyszłości w jednym kawałku.
  5. witam Jaki film znalazles ..... ktory pokazuje ze trzeba caly dach wyciagac ? :duh: Filmiki jakie podalem wyzej pokazuja krok po kroku w jaki sposob wszystko zdemontowac tzn. tylko napęd mechaniczny i jego elementy Drugi filmik pokazuje montaz dachu panoramicznego tzn. napęd - mechanike i jej elementy ( krok po kroku ) UWAGA ! BMW zaleca po naprawie mechanizmu dachu panoramicznego dokladne ustawienie obu plyt szklanych - szerokosc szczelin .... podobnie jak ma to miejsce po wymianie uszczelek dachu panoramicznego. Nie stosujac tych zalecen mozna uszkodzic silnik napedowy lub inne elementy mechaniczne dachu
  6. Zafi
    3.0 SI - BŁĄD 009C60
    witam .... na schematach / rysunkach widac dwa czujniki ( lewy , prawy ) http://fs5.directupload.net/images/160523/toarju36.png
  7. witam @habzimierz : potrzebujesz tlumaczenia artykulu ? Panowie ! Przetlumaczylem tekst ale tylko w miare moich mozliwosci …. Nie jestem specjalista ani tlumaczem - w artykule wystepuja zwroty z wielu roznych dziedzin i to wszystko poprwnie polaczyc stylistycznie w jezyku polskim ….. masakra. :duh: Ponadto wystepuja w artykule zwroty lub pojecia ktore jeszcze nie wystepuja w jezyku polskim np. vernetzte Dynamiklicht ( dynamiczna zmiana swiatel sterowana przez siec ) albo Vorausschaufunktionen auf Navi- und Sensorbasis ( rozne funkcje beda sie zmieniac w zaleznosci od polozenia pojazdu (Navi ) lub innych sensorow. Jezeli ktos ma zastrzezenia , chce poprawic lub pomoc w tumaczeniu to chetnie : prosze pisac na PW ( Prywatna Wiadomosc )
  8. Zafi
    witam tu masz instukcje BMW - wszystko na temat kimatyzacji : http://www.bmwmotorsports.org/pdf/e70/08_E70%20Climate%20Control%20Systems.pdf czy to jest ten czujnik ? http://fs5.directupload.net/images/160523/sov55yl3.png http://fs5.directupload.net/images/160523/orzap7jo.png ... to tutaj jest instrukcja jak sie do tego zabrac :cool2: 64 Heating And Air Conditioning > 11 Heater With Operation > 27 RA Replacing (one) Temperature Sensor For Heater http://workshop-manuals.com/bmw/x_series_e70/x5_3.0sd_m57t2_offrd/2_repair_instructions/64__heating_and_air_conditioning/11__heater_with_operation/27_ra__replacing_%28one%29_temperature_sensor_for_heater/
  9. witam to jest instrukcja BMW : demontaz - BMW E53 E61 E70 E83 E91 Panoramadach Mechanism Disassembly montaz - BMW E53 E61 E70 E83 E91 Panoramadach Mechanism Assembly
  10. witam zdjecia i opis nowego X3 (G01) :D
  11. witam ... pojawily sie informacje na temat następcy X3 (F25) - X3 (G01) 2017 http://www.autobild.de/artikel/bmw-x3-2017-vorschau-und-technik-5198454.html?noMobileCookie=0
  12. witam w zagranicznym forum pojawila sie informacja : BMW oferuje " Zestaw naprawczy serwosilnika" http://fs5.directupload.net/images/160519/p9uhjfii.png w katalogu BMW Nr. 27_0110 http://fs5.directupload.net/images/160519/lytqet3l.png http://fs5.directupload.net/images/160519/57s9e4kk.png Lista czesci http://fs5.directupload.net/images/160519/4d82oqmv.png
  13. witam Nachrüstung Anhängerkupplung abnehmbar BMW X3 (F 25) Instrukcja BMW X3 F25 podwieszany hak holowniczy http://www.motor-talk.de/forum/aktion/Attachment.html?attachmentId=741599 Nachrüstung Anhängerkupplung elektrisch schwenkbar BMW X3 (F25) Instrukcja BMW X3 F25 elektryczny hak holowniczy http://www.motor-talk.de/forum/aktion/Attachment.html?attachmentId=705183
  14. witam 51 Body Equipment (OFFRD) > 16 Mirrors-covers-ashtrays-shelves-trays > 3 RA Overview Of Storage Compartment (centre Console) 51 16 ... Overview of storage compartment (centre console) http://workshop-manuals.com/bmw/x_series_e70/x5_4.8i_n62tu_offrd/2_repair_instructions/51__body_equipment_%28offrd%29/16__mirrors-covers-ashtrays-shelves-trays/3_ra__overview_of_storage_compartment_%28centre_console%29/ @sfinks311 Nr. 6 Fresh-air grille, rear cabin ? https://www.google.de/url?sa=t&rct=j&q=&esrc=s&source=web&cd=8&cad=rja&uact=8&ved=0ahUKEwjwg5uHq9rMAhUJLcAKHX8VCUoQFgg2MAc&url=http%3A%2F%2Fwww.xoutpost.com%2Fattachments%2Fx5-e70-forum%2F35625d1249602865-ac-vent-trim-piece-ra-removing-installing_replacing-rear-cabin-fresh-air-grille.pdf&usg=AFQjCNE1BQpvgGoGSvO0lWls33GberHJ5Q :D
  15. witam Zestaw napr. rynienki odpływowej http://pl.bmwfans.info/parts-catalog/54128119050 .... hej zestaw naprawczy podany wyzej jest do BMW e36 :cry2: @belkocik : jak chcesz stwierdzic, ktore elementy sa zepsute ..... bez rozbierania mechanizmu dachu ? Ponizej elementy dachu BMW E83 - zobacz sam :D Pokrywa dachu przes.-uchyl./rama pods. http://pl.bmwfans.info/parts-catalog/E83N/Europe/X3_2.5si-N52N/L-N/jan2008/browse/sliding_roof_folding_top/slid_lift_roof_cover_ceiling_frame Rama dachu przes.-uchyl. http://pl.bmwfans.info/parts-catalog/E83N/Europe/X3_2.5si-N52N/L-N/jan2008/browse/sliding_roof_folding_top/sliding_lifting_roof_frame ... a ja znalazlem cos takiego: BMW E53 X5 E83 X3 2000-2006 Sunroof Slider Guide Repair Fix Kit http://www.ebay.com/itm/BMW-E53-X5-E83-X3-2000-2006-Sunroof-Slider-Guide-Repair-Fix-Kit-/252274874340 Sunroof Repair Kit for BMW X5 E53 and X3 E83 2000-2006 http://www.ebay.com/itm/Sunroof-Repair-Kit-for-BMW-X5-E53-and-X3-E83-2000-2006-/301645960829?hash=item463b80167d:g:bLYAAOSwpdpVZZkA&vxp=mtr BMW X3 E83-X5 E53 SUNROOF REPAIR KIT http://www.ebay.com/itm/BMW-X3-E83-X5-E53-SUNROOF-REPAIR-KIT-/151753584241?hash=item235537ee71:g:DPwAAOSwqu9VPs53&vxp=mtr
  16. witam ... tutaj masz moj filmik : instrukcja BMW jak zdemontowac panoramedach ( krok po kroku ) BMW E53 E61 E70 E83 E91 Panoramadach Mechanism Assembly ... tutaj masz moj filmik : instrukcja BMW jak poskladac panoramedach ( krok po kroku ) BMW E53 E61 E70 E83 E91 Panoramadach Mechanism Disassembly .... czym smarowac elementy mechaniczne dachu - zalecenia BMW : Cassette Lubricant Würth Glide Grease Part No. 0893898 P.S. .... posiadam ta instrukcje BMW - ( Pdf-a ) 3D - podaj adres internetowy na PW :D
  17. witam http://fs5.directupload.net/images/160511/26t23dyb.png
  18. witam Temat : zmiana oleju w skrzyni biegow manual / automatc : 23 Manual Transmission (MECH) > 0 Complete Transmission > 5 RA Oil Change In Manual Transmission 00 11 229 Oil change in manual transmission http://workshop-manuals.com/bmw/3_series_e90/323i_n52_sal/2_repair_instructions/23__manual_transmission_%28mech%29/0__complete_transmission/5_ra__oil_change_in_manual_transmission/ 24 Automatic Transmission (AUT) > 0 Transmission Assembly > 5 RA Checking_topping Up Fluid Level In Automatic Transmission (GA6L45R) 00 11 237 Checking/topping up fluid level in automatic transmission (GA6L45R) http://workshop-manuals.com/bmw/3_series_e90/323i_n52_sal/2_repair_instructions/24__automatic_transmission_%28aut%29/0__transmission_assembly/5_ra__checking_topping_up_fluid_level_in_automatic_transmission_%28ga6l45r%29/ 2 Repair Instructions > 0 Maintenance And General Data > 47 RA Checking_topping Up Fluid Level In Automatic Transmission (GA6HP19Z) 00 11 237 Checking/topping up fluid level in automatic transmission (GA6HP19Z) http://workshop-manuals.com/bmw/3_series_e90/330i_n52_sal/2_repair_instructions/0__maintenance_and_general_data/47_ra__checking_topping_up_fluid_level_in_automatic_transmission_%28ga6hp19z%29/ ... i jak mocno dokrecac sruby 4 Tightening Torques > 23 Manual Transmission (MECH) > 0 Complete Transmission > 2 AZD Transmission In General 23 00 Transmission in general http://workshop-manuals.com/bmw/3_series_e90/330i_n52_sal/4_tightening_torques/23__manual_transmission_%28mech%29/0__complete_transmission/2_azd__transmission_in_general/ 4 Tightening Torques > 24 Automatic Transmission (AUT) > 11 Transmission Case, Oil Sump > 3 AZD Transmission Housing, Transmission Oil Sump 24 11 Transmission housing, transmission oil sump http://workshop-manuals.com/bmw/3_series_e90/330i_n52_sal/4_tightening_torques/24__automatic_transmission_%28aut%29/11__transmission_case_oil_sump/3_azd__transmission_housing_transmission_oil_sump/ http://workshop-manuals.com/bmw/3_series_e90/330i_n52_sal/4_tightening_torques/24__automatic_transmission_%28aut%29/11__transmission_case_oil_sump/3_azd__transmission_housing_transmission_oil_sump/page_3442/
  19. witam Sprawa transferu ATC450 to dalszy rozwój ATC 400 stosowanego w poprzedniku E83. :D http://www.automaticchoice.es/Catalogo%20AC/Catalogue/tb_atc450.pdf .... a jak zmienic olej w X3/E83 masz tutaj : BMW X3 (E83) 2004-2010 Transfer Case Oil Change - DIY Repair
  20. witam tu masz tabelki - z jaka sila dokrecic sruby pompy wodnej oraz termostatu :D 11 Engine (N52) > 51 Water Pump With Drive > 1 AZD Water Pump And Drive 11 51 Water Pump and Drive http://workshop-manuals.com/bmw/5_series_e60/525i_n52_sal/4_tightening_torques/11__engine_%28n52%29/51__water_pump_with_drive/1_azd__water_pump_and_drive/ 11 Engine (N52) > 53 Thermostat And Connections > 1 AZD Thermostat And Connections 11 53 Thermostat and Connections http://workshop-manuals.com/bmw/5_series_e60/525i_n52_sal/4_tightening_torques/11__engine_%28n52%29/53__thermostat_and_connections/1_azd__thermostat_and_connections/ 11 Engine (N52) > 53 Thermostat And Connections > 2 AZD Thermostat And Connections 11 53 Thermostat and Connections http://workshop-manuals.com/bmw/5_series_e60/525i_n52_sal/4_tightening_torques/11__engine_%28n52%29/53__thermostat_and_connections/2_azd__thermostat_and_connections/
  21. witam 5 Series E60 530d (M57T2) SAL 23 Manual Transmission (MECH) > 0 Complete Transmission > 4 RA Draining_topping Up Gear Oil In Manual Transmission Draining/topping up gear oil in manual transmission http://workshop-manuals.com/bmw/5_series_e60/530d_m57t2_sal/2_repair_instructions/23__manual_transmission_%28mech%29/0__complete_transmission/4_ra__draining_topping_up_gear_oil_in_manual_transmission/ Note: Gearbox must be at normal operating temperature. Gear oil: - Refer to BMW Service Operating Fluids. Filling capacities: - Refer to Technical Data Uwaga: Skrzynia biegów musi być w normalnej temperaturze pracy. Olej przekładniowy: - Patrz Serwis BMW Płyny eksploatacyjne. Wypełnienie możliwości: - Patrz Dane techniczne Draining gear oil: - Release oil drain plug (1) and filler plug (2). - Clean oil drain plug (1) and screw in. Tightening torque 23 00 4AZ Spuszczanie oleju przekładniowego: - Korek spustowy oleju zwalniający (1) i korek wlewu (2). - Oczyścić korek spustowy oleju (1) i wkręcić. Moment dokręcenia 23 00 4AZ Fill transmission with ATF. - Pour in gear oil until overflowing. - Tighten in filler screw (2). Tightening torque: 23 00 4AZ Napełnić przekładnię z ATF. - Wlać olej przekładniowy, aż brzegi. - Dokręcić śrubę wlewu (2). Moment dokręcenia: 23 00 4AZ a tutaj masz tabele z jaka sila dokrecac sruby ! 23 Manual Transmission (MECH) > 0 Complete Transmission > 2 AZD Transmission In General 23 00 Transmission in general http://workshop-manuals.com/bmw/5_series_e60/530d_m57tu_sal/4_tightening_torques/23__manual_transmission_%28mech%29/0__complete_transmission/2_azd__transmission_in_general/ ..... 23 00 4AZ Oil drain plug / filler plug :D B / C - transmission => 50Nm D / E - transmission => 52Nm G / H - transmission ( M18x1.5 hexagon socket ) => 35 Nm H / I - transmission ( M12x1.5 ) => 25 Nm J - transmission => 40 Nm
  22. witam :cool2: .... a tu masz instrukcje jak wymienic pompe i termostat : NG6 Engine Thermostat and Water Pump Replacement http://www.pelicanparts.com/techarticles/BMW-E60/73-WATER-Water_Pump_and_Thermostat_Replacement/73-WATER-Water_Pump_and_Thermostat_Replacement.htm 53 Thermostat And Connections > 1 RA Removing And Installing_replacing Coolant Thermostat (N52) http://workshop-manuals.com/bmw/5_series_e60/530i_n52_sal/2_repair_instructions/11__engine_%28n52%29/53__thermostat_and_connections/1_ra__removing_and_installing_replacing_coolant_thermostat_%28n52%29/ 51 Water Pump With Drive > 1 RA Removing And Installing_replacing Water Pump (N52) http://workshop-manuals.com/bmw/5_series_e60/530i_n52_sal/2_repair_instructions/11__engine_%28n52%29/51__water_pump_with_drive/1_ra__removing_and_installing_replacing_water_pump_%28n52%29/ 1 RA Removing And Installing_replacing Water Pump (N52) > Page 421 http://workshop-manuals.com/bmw/5_series_e60/530i_n52_sal/2_repair_instructions/11__engine_%28n52%29/51__water_pump_with_drive/1_ra__removing_and_installing_replacing_water_pump_%28n52%29/page_421/ Ważne! Materiały aluminiowo-magnezowe. Brak stalowych wkrętow / śruby są stosowane ze względu na zagrożenie korozji elektrochemicznej. Blok korbowy z magnezu wymaga wyłącznie aluminiowych śrub / sworzni . Aluminiowe śruby / nakrętki muszą być wymieniane za każdym razem na nowe. Czół śrub aluminiowych / śruby są pomalowane na niebiesko celem niezawodnej identyfikacji. Łączenie momentu obrotowego i kąta obrotu muszą być zawsze przestrzegane (ryzyko uszkodzenia). Jeżeli pompa wodna, która została już obsługiwany jest wykorzystywany, to muszą być wypełnione natychmiast po wyjęciu z chłodziwem (Stosunek mieszania 1: 1 / woda: płyn chłodzący). Dla zainteresowanych podajejeszcze instrukcje, jak sprawdic pompe : Electric Water Pump Testing http://www.pelicanparts.com/techarticles/BMW-E60/15-WATER-Electric_Water_Pump_Testing/15-WATER-Electric_Water_Pump_Testing.htm
  23. witam 12 litrow ? tutaj : http://www.pelicanparts.com/techarticles/BMW-E60/23-WATER-Draining_Filling_Cooling_System/23-WATER-Draining_Filling_Cooling_System.htm 6-cylinder engines used in BMW E60 automatic transmission models hold about 10.6 liters of coolant. Manual transmission models hold 10 liters. silniki 6-cylindrowe stosowane w modelach BMW E60 automatyczna skrzynia biegów posiadają około 10,6 litrów płynu chłodzącego. Manualna skrzynia biegów modele posiadają 10 litrów. 8-cylinder engines used in BMW E60 automatic transmission models hold about 14.2 liters of coolant. Manual transmission models hold 13.8 liters. 8-cylindrowe silniki stosowane w modelach BMW E60 automatyczna skrzynia biegów posiadają około 14,2 litrów płynu chłodzącego. Manualna skrzynia biegów modele posiadają 13,8 litrów.
  24. tu jest wszystko na temat pompy : orginal Firma Pierburg http://atlanticmotorcar.com/bmw-engine-water-pump-failure-how-why-and-what-to-prevent/ .... a tutaj filmik : Electric water pump dissection from an E60 BMW 5 Series 2007 orginal Firma Pierburg http://fs5.directupload.net/images/160507/fai9ouer.png .... a moze to nie pompa tylko czujnik temperatury ? np. podaje temperature nieprawidlowo ?
  25. witam tu jest instrukcja odpowietrzenia ukladu chlodniczego np. po wymianie pompy :D http://www.motor-talk.de/forum/aktion/Attachment.html?attachmentId=734421 Achtung! Lifetimebefüllung Kühlmittel: Gebrauchtes Kühlmittel grundsätzlich nicht wiederverwenden! Bei Tausch und bei Ausbau von Bauteilen, die auf die Korrosionsschutzwirkung des Kühlmittels angewiesen sind, muss dieses ersetzt werden. Das Kühlsystem muss daher entleert und neu befüllt werden. Bei sonstigen Demontagearbeiten, bei denen Teilmengen des Kühlmittels abgelassen werden, wird dieses durch neues Kühlmittel ergänzt. Uwaga! Żywotność napełniania plynu : Używany plyn w zasadzie nie używać ponownie! Przy wymianie lub demontazu komponentów, które są zależne od efektu ochrony przed korozją chłodziwa, należy je wymienić. Układ chłodzenia musi zostać opróżniony i napełniony ponownie. Przy innych prac demontażowych, gdzie czesc plynu zostala spuszczona, braki nalezy uzupelnic nowym plynem chłodniczym. Nur beim Nachfüllen! Nur vorgeschriebenes Kühlmittel verwenden. Mischungsverhältnis beachten! Befüllung langsam durchführen. Kühlmittelstand auf max abgleichen. Tylko wtedy, gdy uzupelniamy! Należy używać tylko zalecanego płynu chłodzącego. Uwaga . Zachowac stosunek mieszania! Wypełnienie ( uzupelnianie ) wykonywać powoli. Poziom płynu chłodzącego na max. Ausgleichsbehälter für Kühlmittel schließen. Einbauhinweis: Verschlussdeckel (1) soweit schließen, bis die Pfeilmarkierungen fluchten. Zbiornik wyrównawczy dla płynu chłodzącego zamknac. Instalacja: Korek (1) zakrecic az do wyrownania oznaczen . Kühlsystem entlüften: Hinweis: Während des Entlüftungsvorgangs den Verschlussdeckel des Ausgleichsbehälters für Kühlmittel nicht öffnen. 1. Batterieladegerät anschließen. 2. Zündung einschalten. 3. Heizung auf maximale Temperatur stellen, Gebläse auf kleinste Stufe zurücknehmen. 4. Gaspedal für 10 Sekunden bis Anschlag drücken. Motor darf nicht gestartet werden. 5. Der Entlüftungsvorgang wurde durch Drücken des Gaspedals gestartet und dauert ca. 12 Minuten. (Die elektrische Kühlmittelpumpe wurde aktiviert und schaltet sich nach ca. 12 Minuten automatisch ab). 6. Danach Füllstand im Ausgleichsbehälter für Kühlmittel mit 100 ml über max befüllen (siehe Bild R17 0450) 7. Kühlsystem auf Wasserdichtheit prüfen. 8. Falls die Entlüftung nochmal durchgeführt werden muss, (z.B. bei undichtem Kühlsystem)DME komplett abfallen lassen (ca. 3 Minuten Zündschlüssel abgezogen lassen), dann ab Punkt 3 wiederholen. Nur beim Entlüften! Befüllung langsam durchführen. Ausgleichsbehälter für Kühlmittel mit 100 ml über max befüllen. 100 ml entsprechen A=6 mm. Odpowietrzanie układu chłodzenia: Uwaga: Podczas odpowietrzania nie otwierac/ odkrecac korka zbiornika wyrównawczy płynu chłodzącego. 1. Podłącz ładowarkę. 2. Włączyć zapłon. 3. Ustawic grzejnik na maksymalną temperaturę, wentylator na najmniejszy stopien. 4. Wciśnij pedał przyspieszenia (gazu) przez 10 sekund, az do oporu. Nie uruchamiac silnika. 5. Procedura odpowietrzania zostala uruchomiona przez wcisniecie pedalu gazu i trwa około 12 minut. ( Elektryczna pompa płynu chłodzącego została aktywowana i zostanie wylaczona po około 12 minutach automatycznie ). 6. Nastepnie uzupelnic plyn w zbiorniku wyrównawczym 100 ml powyższej max (patrz rysunek R17 0450) 7. Sprawdzić szczelność układu chłodzenia. 8. Jeżeli odpowietrzenie musi być wykonane ponownie, (np. w przypadku nieszczelności w układzie chłodzenia) DME wylaczyc (wylaczyc zaplon na 3 minuty ) , powtórz czynności od punktu 3. Tylko przy odpowietrzaniu! Napelnianie / uzupelnianie dokonywac powoli. Napełnić zbiornik wyrównawczy plynu chłodzacego 100 ml powyżej max. - 100 ml odpowiadają = 6 mm.
