maniek21112
  • Wygrane w rankingu
    3
  1. Jeszcze kiera jest sportowa a nie m-pakietowa. Zależy kto i jak dokładnie zrobi przegląd. Jeszcze dołożone są grzane stołki albo sam panel i przyciski atrapy.
  2. VIN: WBAAY72040KJ89918 Type code: AY72 Model: 318I (EUR) E-F-R series: E46 4FL Series: 3 Type: LIM Steering: RL Doors: 4 Engine: N42 Displacement: 2.00 Power: 105 (143 hp) Drive: HECK Transmission: MEC Paint code: 490 - SONDERLACKIERUNG Upholstery code: G7AT - STOFF LASER/ANTH Prod.date: 2003-11-18 S1CA SELECTION COP RELEVANT VEHICLES S8SP Control unit CO2 S169 EU3 exhaust emissions standard S210 Dynamic stability control III S226 Sports suspension settings S249 Multifunction f steering wheel S302 Alarm system S320 Deleted, model lettering S338 M Sports package II S411 Window lifts,electric,front/rear S428 Warning triangle and first aid kit S431 Interior rear-view mirror with auto dip S441 Smoker package S473 Armrest front S481 Sports seat S493 Storage compartment package S495 3-point belt head restr'nt,rear middle S508 Park Distance Control (PDC) S520 Fog lights S534 Automatic air conditioning S550 On-board computer S650 CD player S661 Radio BMW Business (C43) S692 Preparation, BMW 6-CD changer I-bus S710 M leather steering wheel S716 Aerodynamics package S760 High gloss shadow line S770 Interior trim trips, Alu Silver Cube S775 Headlining anthracite S785 White direction indicator lights S788 BMW LA wheel, Individual L812 National version England / Ireland S832 Battery in luggage compartment S850 Additional Export tank filling S853 Language version, English S863 Dealer List Europe S877 Omission of non-combined operation S880 Operating instructions, English S938 Individual series ======================================== Individual equipment ======================================== ---- Processing Individual Sign quot;BMW individualquot; ---- Special Series E46 Individual series for V3, KA187 Variant 3 0490 Color Paintwork quot;le mans blue-metallicquot;, as code 381.
  3. Zaraz za zderzakiem, dojście od dołu.
  4. Błędy na początek.
  5. W trakcie wypalania automat zmienia biegi później, więc bez obaw.
  6. Jeżeli czyszczenie chwilowo pomogło to oznacza, że zawór przycina się, więc albo mechanik nie przyłożył się albo czeka Cię wymiana. Steruje nim przetwornik ciśnienia (elektrozawór) i to on może też być przyczyną.
  7. To nie znaczy, żeby do niej nie zajrzeć, ale luz to sprawdziłbym wzdłużny, poprzeczny zawsze lekki jest, oczywiście nie taki żeby wirnik dotykał korpusu. Zdejmij osłonę silnika i sprawdź czy nie masz wycieku, bo wygląda, że olej spływa na kolektor wydechowy.
  8. Dobrze by było jakbyś podał błędy z inpa, bo podejrzewam, że był sprawdzany jakimś uniwersalnym sprzętem, powinno to wnieść sporo do tematu, mogli pominąć coś co nie miało opisu a jest przyczyną. Nie powiązałbym tego z odmą, ciekawe jak to było diagnozowane.
  9. Zrób test na obecność spalin, korek 1.4b? Oryginał? Pompa wody sprawdzona? Jest przelew? Jaką masz temperaturę?
  10. Podejrzyj pracę vanosów (inpa) w momencie braku mocy, podejrzewam, że problem jest z czujnikiem wałka rozrządu dolotowym, ale to trzeba potwierdzić sprawdzeniem vanosów.
  11. Brak mocy jest pewnie skutkiem tego czujnika a dźwięk tak jak piszesz najlepiej nagraj.
  12. To bliżej wtyczki. Jeżeli podciśnienie jest ok to trzeba zainteresować się przetwornikiem (elektrozaworem), przydałby się podgląd na masę powietrza. Z dpf coś robiłeś, długo masz już jego błąd? Temperaturę silnika masz w normie?
  13. maniek21112
    528i 96r utrata mocy
    Błędy to nie wszystko, trzeba sprawdzić parametry.
  14. Powinien włączyć się, sprawdź go na krótko czy działa, jak tak to wina sterownika, elektronik powinien poradzić sobie z nim. Jeszcze żeby wykluczyć problem z układem chłodzenia (a jakiś masz skoro masz ubytek) to możesz uruchomić go przez inpa.
  15. Przejedź się dynamicznie i po zatrzymaniu dotknij każdej felgi, jak któraś będzie cieplejsza to tłoczek w tym zacisku nie odbija.
  16. Musisz rozkodować vin, seryjne amortyzatory wytrzymają obniżenie o 30mm.
  17. maniek21112
    Pasuje do czujnika wałka rozrządu. Vanos dobrze pracuje? Sprawdzone na komputerze?
  18. Zmieniaj na 5w40 bezstresowo
  19. maniek21112
    Czujnik ABS problem
    W instalacji, albo czujnik był uszkodzony.
  20. Zbiorniki wyrównawcze też bardzo często pękają, więc zwróć na to uwagę. Nie jeździj z tym klejem, tylko jak najszybciej przepłucz układ i obserwuj temperaturę w teście 7.0, bo pion jest do 115 stopni a powyżej 100 to już jest niewskazane dla tego silnika.
  21. Nie może być ma komputerze ok jak nie ma mocy, ewentualnie jeździsz na ręcznym albo masz zapieczone zaciski i tłoczki nie odbijają.
  22. maniek21112
    320d - Intercooler
    Wyskoczyła z mocowania czy pękła? Może zapinka nie trzyma dobrze albo zabezpieczenie na rurze jest wyrobione.
  23. VIN: WBANC91030CU78165 Type code: NC91 Model: 535D (EUR) E-F-R series: E60 Series: 5 Type: LIM Steering: LL Doors: 4 Engine: M57X Displacement: 3.00 Power: 200 (272 hp) Drive: HECK Transmission: AUT Paint code: 416 - CARBONSCHWARZ METALLIC Upholstery code: LCSW - LEDER DAKOTA/SCH Prod.date: 2006-09-13 S1CA SELECTION COP RELEVANT VEHICLES S2NP BMW alloy wheel, M double spoke 135 S5AC High-beam assistant S6AA BMW TeleServices P7R7 Innovation package S8SA Navigation access request,country-spec. S8SP Control unit COP S205 Automatic transmission S320 Deleted, model lettering S322 Comfort access P337 M Sports package S423 Floor mats, velours S428 Warning triangle and first aid kit S431 Interior rear-view mirror with auto dip S435 Fine wood trim S442 Drink holder S456 Comfort seat with memory S494 Seat heating driver/passenger S502 Headlight cleaning system S508 Park Distance Control (PDC) S522 Xenon Light S524 Adaptive Headlights S534 Automatic air conditioning S540 Cruise control S548 Kilometre speedo S609 Navigation system, Professional S610 Head-up display S612 BMW Assist S616 BMW Online S620 Voice control S633 Preparation, mobile phone, Business S672 CD changer for 6 CDs S676 HiFi speaker system S698 Area-Code 2 for DVD S704 M Sports suspension S710 M leather steering wheel S715 M Aerodynamics package S760 High gloss shadow line S761 Individual sunshade glazing S775 Headlining anthracite L801 NATIONAL VERSION GERMANY S851 Language version German S863 Dealer List Europe S879 Operating instructions German
  24. VIN: WBA3D310X0F240216 Type code: 3D31 Model: 320D (EUR) E-F-R series: F30 Series: 3 Type: LIM Steering: LL Doors: 4 Engine: N47T Displacement: 2.00 Power: 135 (183 hp) Drive: HECK Transmission: AUT Paint code: 475 - BLACK SAPPHIRE METALLI Upholstery code: LCL3 - LEDER DAKOTA/SCH Prod.date: 2012-02-03 S1CA SELECTION COP RELEVANT VEHICLES S2A6 17"LM RAEDER DOPPELSPEICHE 392 S2PA Lockable wheel bolt S2TB Sport automatic gearbox S4AD Interior trim strips, brushed aluminium S4AE Armrest front, retractable S4DN AKZENTLEISTEN KORALLROT MATT S5DA Passenger airbag deactivation S5DC Rear-seat headrests, folding S6AA BMW TeleServices S6AB Control, Teleservices S6NH FREISPRECHEIN. M. USB-SCHNITTSTELLE S6VA CIC assignment S6WA INSTRUMENTENKOMBI. M. ERW. UMF. P7AC BMW SPORT LINE S7NH BMW Service inclusive S8A1 Sprachversion polnisch S8AT POLNISCH BETRIEBSANL./SERVICEHEFT S8KA OELWARTUNGSINT. 30.000KM/24MONATE S8SC Telematics access request,country-spec. S8V7 HINWEISSCHILD NCAP GRIECH/UNGAR/POL S216 HYDRO STEERING-SERVOTRONIC S230 Extra package, EU-speciifc S249 Multifunction f steering wheel S255 Sports leather steering wheel S258 Tyres with runflat properties S302 Alarm system S423 Floor mats, velours S428 Warning triangle and first aid kit S430 Interior/outside mirror with auto dip S431 Interior rear-view mirror with auto dip S441 Smoker package S465 Through-loading system S481 Sports seat S494 Seat heating driver/passenger S502 Headlight cleaning system S508 Park Distance Control (PDC) S520 Fog lights S521 Rain sensor S522 Xenon Light S534 Automatic air conditioning S548 Kilometre speedo S609 Navigation system, Professional S698 Area-Code 2 for DVD
  25. Zapytaj o zdjęcia tu: viewtopic.php?f=44&t=186938&start=6765 Podaj vin i link. VIN: WBANV93558CW56821 Type code: NV93 Model: 535XI (USA) E-F-R series: E60 LCI (LifeCycleImpulse) Series: 5 Type: LIM Steering: LL Doors: 4 Engine: N54 Displacement: 3.00 Power: 225 (306 hp) Drive: ALLR Transmission: AUT Paint code: A68 - PLATINGRAU METALLIC Upholstery code: LCSW - LEDER DAKOTA/SCH Prod.date: 2007-05-08 S1CA SELECTION COP RELEVANT VEHICLES S2SC BMW LA wheel, start spoke 243 S2VB Tyre pressure control (TPC) S6FL USB/audio interface S6UH Traffic Information S8SP Control unit COP S9AA Outer skin protection S203 4-wheel drive S205 Automatic transmission S248 Steering wheel heater S255 Sports leather steering wheel S261 Side airbags for rear passengers S302 Alarm system S319 Integrated universal remote control S322 Comfort access S339 Shadow-Line S354 Green windscreen, green shade band S403 Glass roof, electrical S430 Interior/outside mirror with auto dip S431 Interior rear-view mirror with auto dip S438 Fine wood trim S441 Smoker package S442 Drink holder S456 Comfort seat with memory S473 Armrest front S494 Seat heating driver/passenger S496 Seat heating, rear S502 Headlight cleaning system S522 Xenon Light S524 Adaptive Headlights S534 Automatic air conditioning S544 Cruise control with brake function S563 Light package S609 Navigation system, Professional S611 BMW Night Vision S620 Voice control S639 Preparation f mobile phone cpl. USA/CDN S645 BMW US Radio S653 High Definition Radio S677 HiFi system Professional DSP S693 Preparation BMW satellite radio S694 Provisions for BMW 6 CD changer S697 Area-Code 1 for DVD S818 Battery master switch S823 Hot-climate version S845 Acoustic fasten seat belt reminder S850 Additional Export tank filling S853 Language version, English S876 Radio frequency 315 MHz S925 Dispatch protection pack S992 Control of number-plate attachment
