Panie i Panowie, a jak to z tym olejem w skrzyni automatycznej? zmienić? kiedy? 120tyś km to juz czas czy jak nic sie nie dzieje to jednak ryzyko ze będzie gorzej a nie lepiej? przejrzałem wątek i tylko #Giacomo4 napisał ze zmieniał ale bez wiekszych szczegółów i od razu dokładam bo znalazłem ciekawe info w manualu od ZF 5. Maintenance recommendations ZF automatic transmissions 3/4-speed automatic transmissions: ZF 3 and 4-speed automatic transmissions must be filled with approved ATF oils according to ZF list of lubricants TE-ML 11, lubricant class 11A / 11B or with mineral ATF oils according to the former Specification Dexron II / Dexron III by General Motors. For oil-change intervals consult the vehicle manufacturer's specifications. 5-, 6-, 8- and 9-speed as well as 4HP20 automatic transmissions: ZF 5-, 6-, 8- and 9-speed as well as the ZF 4HP20 automatic transmissions are filled maintenance-free with specially developed partially synthetic ATF oils. Maintenance-free fills are intended for normal operating conditions. Especially driving at very high operating temperatures can result in accelerated aging or increased wear of ATF oils. In case of above-average operating conditions, such as: - frequent freeway driving in the upper speed range - offensive, sporty driving style - frequent trailer operation it is recommended to refresh (change) the oil of the automatic transmission every 100,000 km or no later than after 8 years. In each case, only released ATF oil may be used for oil changes. And oil changes must be performed in accordance with the relevant specifications. The exception is the ZF 5HP18 automatic transmission which must be filled differently depending on the version. The released ATF oils in each case are specified in the ZF Lubricants List TE-ML 11. https://www.zf.com/global/media/en_zf/lubricantslists/TE-ML_11.pdf
